no casting number on heads?
Old Aug 12, 2007 | 06:01 PM
Mitch.Shea's Avatar
Mitch.Shea
Default no casting number on heads?
checked out my heads on my 99 FRC and they have no casting to numbers like they have been milled off then polished... car looked like it had some mods before i got it that he had taken off.. do you think i have ported stock heads?
Old Aug 12, 2007 | 07:47 PM
Mitch.Shea's Avatar
Mitch.Shea
Old Aug 12, 2007 | 10:08 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Pull the valve cover and look in the center of the head for the part # which will be displayed #### ####
Old Aug 13, 2007 | 02:17 AM
Mitch.Shea's Avatar
Mitch.Shea
i will have to do that next weekend.. any way of telling from the outside? wish i could contact the last owner
Old Aug 13, 2007 | 08:46 AM
JoeyG's Avatar
JoeyG
Numbers are cast on the outside boss areas and then on the inside on cylinders 2 and 4 or 3 and 5
Old Aug 13, 2007 | 09:04 AM
Redvette_22's Avatar
Redvette_22
I've seen the same thing on my buddies car, for what ever reason the on passenger side, where you'd expect to see the casting number clearly, it seemed to have been milled clean and shiny. His car however, was purchased new and he was the original owner so it never had the heads off.
Old Aug 13, 2007 | 09:12 AM
AU N EGL's Avatar
AU N EGL
Head casting numbers:
853 and 241 are basically identical.
853 was used on 99-00 LS1 engines.
241 was used on 01-04 LS1 engines.
They both have a 66.67 cc combustion chamber (10.1 CR), 200cc intake runners, and 70cc (round) exhaust ports.
The 243 head is the 01+ LS6/LS2 head.
It has a smaller 64.45cc chamber for more compression (10.5 CR on LS6), 210cc intake runners, and 75cc D-shaped exhaust ports.
All three came with 2.00" intake valves, and 1.55" exhaust valves.
Of the three, the 243 (Z06) head is the most desirable for flow, and is the most popular base for further porting/modifying. Not many people mess with porting LS1 heads anymore.
Old Aug 13, 2007 | 10:04 AM
regorih's Avatar
regorih
LOL! my car is the same, my car is a 99 and on the passenger side of the front of the heads the number is not there....same thing like if it was milled off or something. Look at the rear of the head or look at the driver side of the car but, you will need to remove the alternator. My car has 853 casting heads.
Roger
Old Aug 13, 2007 | 11:52 PM
Mitch.Shea's Avatar
Mitch.Shea
Roger
thanks i thought i was going to get lucky and have some ported heads.
Old Aug 14, 2007 | 12:16 AM
Ryan L's Avatar
Ryan L
You never know. The easiest way it to get it dynoed and see if it makes above average numbers.
Old Aug 14, 2007 | 12:38 AM
Mitch.Shea's Avatar
Mitch.Shea
im sure im going to upgrade those heads down the road.
To no casting number on heads?
