How cold should the plug heat range be??
Old Aug 12, 2007 | 09:44 PM
Vettedreamer2's Avatar
Vettedreamer2
Default How cold should the plug heat range be??
What effect on horsepower could there be if the spark plugs are too cold? (heat range not tempature)
My issues is wheather tr6's (two steps colder than stock) are too cold on an 455rwhp ls1 na.
Old Aug 12, 2007 | 10:39 PM
noahdr's Avatar
noahdr
your plugs probably wont last very long, overheating them will make them flimsy and weak and could fall apart inside your engine I'd use the AC Delco Iridiums to be safe.
Old Aug 13, 2007 | 05:55 AM
vettenuts's Avatar
vettenuts
NGK recommends one range colder for each additional 100 hp. I thought the TR6's were one range colder, not two. Unless the plugs are telling you that they are too cold by inspection, I think you have the correct plug for your setup. Better to be colder than hotter if you are going to error on heat range.
Old Aug 13, 2007 | 06:02 AM
b98's Avatar
b98
good info. thanks
To How cold should the plug heat range be??
