Water Pump Replacement/Harmonic Balancer Wobble
Old Aug 18, 2007 | 03:40 PM
Torqued84's Avatar
Torqued84
Default Water Pump Replacement/Harmonic Balancer Wobble
I've done a search and found a lot of info on replacing the harmonic balancer and wobble but haven't found anything on whether the harmonic balancer wobble could be caused by replacing the water pump, both belt tensioners, and both belts. I'm pretty sure the balancer didn't wobble before the stealership changed the above parts. Is there something they could have screwed up in the process that would cause the wobble? I'm afraid if I take it in, without help from the forum, they will just tell me they need to replace the harmonic balancer which will cost between $600 and $1000's, and I wouldn't know any better.
Old Aug 18, 2007 | 03:52 PM
vettenuts's Avatar
vettenuts
Its possible if the balancer was weak, with a weak tensioner, that it was less noticeable. With a new tensioner and more load on the balancer, it may have exacerbated an already bad situation.
Old Aug 18, 2007 | 05:26 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the crank pulley has a rubber 'ring' between the inner and outer hub that fails over time, sometimes completely seperating
Old Aug 18, 2007 | 07:46 PM
gonbad's Avatar
gonbad
My seperated and the outer ring slid back taking out the front engine cover and oil pan. Was a good excuse to do the cam swap as it was just a few more bolts.
If you are going to replace the balancer do not use a stock unit. The aftermarket pieces are much higher quality. Been thinking about a cam? Then now is the time.
Old Aug 18, 2007 | 10:33 PM
Torqued84's Avatar
Torqued84
Thanks for the help. It sounds like the new belts and tensioners may have increased the load, possibly exacerbating the wobble but doesn't indicate a bad installation of the new parts. So now I will shop around and check on some aftermarket pulleys, perhaps an underdrive pulley, and prices to install. I also need to do some research on cams, because I had not been considering them, but if they are a good idea for me, now would seem to be the time to do it, as well as replacing timing cover seal.
Any advice on new pulleys?
Cam recommendations (I never race the car, only driven occasionally (couple times a week, sometimes spirited, sometimes take it on weekend trips)?
Old Aug 18, 2007 | 10:50 PM
04BlueGoose's Avatar
04BlueGoose
Just got my 25% underdrive Powerbond in yesterday from New Era. It is a really nice piece and the price was reasonable through the website www.neweraperformanceparts.com
Old Aug 18, 2007 | 10:57 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
Powerbond is an excellent pulley. ATI is even better but it costs significantly more. The cam choice is something you need to do some research on and then contact a good tuner and tell them what you are looking for as far as gains and driveability are concerned. There is anything from mild to wild out there, it just depends on what you want. Check my sig for a video of mine.
Old Aug 18, 2007 | 11:18 PM
Torqued84's Avatar
Torqued84
Jason,
Love the Electron Blue! It's almost as nice as my Dark Blue Metallic
Cool vid, that car sounds tuff!!!
Old Aug 19, 2007 | 11:01 PM
Torqued84's Avatar
Torqued84
ttt
Old Aug 20, 2007 | 10:23 AM
gonbad's Avatar
gonbad
Look at my sig. That is a somewhat mild cam. If drivability is a big issue with you then I would probably not go any bigger than what I have and I would recommend going with a higher LSA like a 114 or 115. It will provide better idle quality. Don't let anyone tell you that a cam does not impact drivability. They all do and they all require computer tuning just to a different degree.
Doing a cam is not inexpensive. The only reason to do it now is that most of the more difficult labor is being done to replace the balancer. However you will need other parts as well that will add to the expense like new push rods, springs, retainers, possibly a new timing chain plus the cam. Tuning will be about another $400 - $500. So don't just jump in with both feet. I did my own install but I think a good ball park figure including tuning is around $2,000 including all the parts and install.
Powerbond and ASP both make good pulley's. Since you don't race you car I would not mess with an UD pulley. You only gain like 5hp so you are not leaving much on the table.
Old Aug 20, 2007 | 09:30 PM
Torqued84's Avatar
Torqued84
Thanks for the cam advice. I think I'm going to pass on a cam install. Because I only drive on the street, the cost/benefit isn't worth it for ME. I'm sure it is worth it to others. Thanks again for the help.
Old Aug 21, 2007 | 12:22 PM
road dog's Avatar
road dog
If the water pump was leaking on your harmonic balancer this will cause
the stock balancer to wobble the rubber used inbetween the two parts used to make the stock balancer will become soft and cause it to start to come apart this happened to me . my balancer came apart I replaced it with a fluidampner from summit the car runs much smoother it self balancing and power bonded and it will not come apart you only want to do it once
98 m6
Old Aug 21, 2007 | 12:43 PM
Torqued84's Avatar
Torqued84
the stock balancer to wobble the rubber used inbetween the two parts used to make the stock balancer will become soft and cause it to start to come apart this happened to me . 98 m6
That sounds logical. Thanks!!
Old Aug 26, 2007 | 07:06 PM
Torqued84's Avatar
Torqued84
Today while running the A/C, I've noticed that the A/C fan makes a squeaking noise when turning the steering wheel hard. This doesn't sound normal to me. Does it indicate anything specific?
To Water Pump Replacement/Harmonic Balancer Wobble
