Tire Sensor??
Old Aug 19, 2007 | 08:23 PM
Wickd1's Avatar
Wickd1
Default Tire Sensor??
Riding down the road today i look down, and see a message about checking my tire sensor or something like that, i check the tire pressure on my dic. and the front left says 32 the right says Rxxxx0 or something like that, is that probally a sensor gone bad?
thanks
Old Aug 19, 2007 | 08:32 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Could be if it does it with regularity.........if it's ok next time around probably just a glitch. How many miles on the sensors?
Old Aug 19, 2007 | 08:38 PM
Wickd1's Avatar
Wickd1
As far as i know 77000 on them . Looks like after reading it probally is a bad sensor or it could just be a gitch like you say, 2 weeks ago my wipers went all crazy for no reason and they havent acted strange since that 1 time,
Old Aug 19, 2007 | 08:42 PM
mrm1149's Avatar
mrm1149
If it doesn't straighten itself out try this........a year or so ago I had one acting goofy and this is what I did, no problem since.
Fill the offending tire up to around 40 lbs or so then drive a few miles on it..........go home and let the air out to normal pressure ( I use 29 cold and tires wear perfectly). After I did that mine has functioned normally and I have no idea why
Old Aug 19, 2007 | 08:44 PM
02MillenniumVette's Avatar
02MillenniumVette
You probably need to replace the sensor. They dont last forever. I have one that is doing that but havent had the time to go get it replaced. I just keep an eye on that tire more.
Old Aug 19, 2007 | 08:51 PM
Wickd1's Avatar
Wickd1
Thanks guys , i just drove the car and its fine now. Hmmmmm ill try the 40lbs of air thing, if all else fails then at some time ill replace the sensors, since i dont run runflats its no big deal , just a mental thing just knowing something isnt working perfect on my perfect car
thanks for the help
Old Aug 19, 2007 | 10:29 PM
jrose7004's Avatar
jrose7004
The battery is dead on that one. Time to buy a new one.
Old Aug 20, 2007 | 11:26 AM
jovette's Avatar
jovette
thanks
I agree that it sounds like a sensor battery going bad. I have all the original sensors in my white/torch red 2000 coupe, and they are still working fine, but then it only has 19,500 miles on it. I have an extra set of used sensors, so I'm going to try the battery install myself, and see how it goes when the time does come to change them.
To Tire Sensor??
