Door Shell Replace - Swapping Internals
Old Aug 21, 2007 | 08:19 PM
LRRLVETTE's Avatar
LRRLVETTE
Default Door Shell Replace - Swapping Internals
Any other advice would be appreciated. Thank you!
Old Aug 22, 2007 | 10:44 AM
SilvaDragon's Avatar
SilvaDragon
You actually want the window part way down.
This lets you get at the retainers that hold the window to the
regulator, but also lets your assistant have a firm grasp of the
window glass while you remove and later re-install it.
Once you get the door panel off, it will be pretty obvious when
the window is in about the right position for this operation.
Last edited by SilvaDragon; Aug 22, 2007 at 10:46 AM. Reason: I meant interior door panel, not the skin of the door.
