Annoying AH Problem
Old Nov 3, 2007 | 10:19 PM
TheDVS1's Avatar
TheDVS1
Hey Bill, thanks for the gut shots of the sensors. Interesting photo-essay there. So basically the sensors are miniature alternators that send a progressive voltage signal to the EBCM? DeeGee said the problem happened under light braking, so perhaps the signal generated is not large enough at that point. He mentioned that things were OK under heavier braking. Perhaps it is a rough connection and the signal isn't quite getting thru.
Thanks for the education!
Old Nov 4, 2007 | 02:51 AM
DeeGee's Avatar
DeeGee
Originally Posted by Bill Curlee
DeeGee
Take a CLOSE look at your wheel alignment. If your steering wheel is misaligned to the left or right while your wheels are actually STRAIGHT, the Steering Wheel Position Sensor (SWPS) will tell the EBTCM that you want to be turning (what ever way the steering wheel is pointing) and the accelerometers will be telling the EBTCM "Hea, were actually going straight!!" and it will cause the EBTCM to try to correct the direction of the car by applying the brakes on one or two wheels.
The C1278 DTC is TCS Temporaliry Inhibited by the PCM. If this DTC is present, you "SHOULD" also be seeing some other DTC which is actually causing the C1278 to set. How are you reading the DTCs????? Are you using the C5 DIC DTC or an aftermarket DTC Code reader?
Make sure that there are not any other DTC present. If they are ,,please list them.
If there are not any other DTCs, you could have a bad EBTCM. In that case,,,I would contact one of the EBTCM Forum rebuilders, give them your symptoms and see if they can rebuild it for you. There are some EBTCM problems that can NOT be repaired.
Please let me know if you have any more questions
BC
Bill
Thanks as always for the great advice.
The wheel is fractionally off but we really are talking a hairs breadth. Just a tad to the left. How tight are those tolerances? What I cant figure is if the sensor is sending a signal that the wheel is off why the difference in light or heavy braking?
Its actually a C1287H that sets which is the SWPS. No other codes at all. I'm using the DIC to read them. I already had a brand new EBCM at about 28k miles and I only have 36k now. At that time I was throwing a C1214 and the replacement fixed that. I'm tending more towards sensors at present.
I've just had it up on the ramps and taken a look at those connectors. They were dirty but looked sound. I gave them a good clean with electrical cleaner so we'll see if that makes any difference. The ones on top of the chassis frame are PITA to get at.
I may have to bite the bullet and change out that SWP sensor if this doesn't fix it. Not looking forward to that.
Old Nov 4, 2007 | 07:53 AM
DeeGee's Avatar
DeeGee
Default Maybe its fixed
Well I just took two runs out today having cleaned up the hub connectors and maybe I'm onto something.
Two 25 mile runs and than two five mile trips and not a single trip. A good selection of country lanes and some long straight stretches as well.
The AH is not chattering as much even under gentle braking. I just had one very slight jitter but it didn't cause a trip. Its definitely way better than it was so it looks like the conenctors are the problem.
If a shot of electrical cleaner has done the job I'll be well happy. Thanks Bill for posting the thread on the connectors. You may even have forgotten that one as it was many moons ago. Thanks also to BlackZ06 for the help
Old Nov 17, 2007 | 02:50 AM
DeeGee's Avatar
DeeGee
Default Deep Gloom
Well another potential fix out the window It seems better but I'm still getting trips.
I've tried a bit more fault finding. On a long straight stretch of road I tried the cruise control. It tripped out and took 3 attempts to engage.
The AH trips seem to be more common in one particular section of the drive to work. Again a long straight road with a switchback. The hills and valleys are quite steep and I've had a couple of trips there. I tried disengaging AH for that stretch and it tripped out even though it wasnt selected. AH trips out TCS stays engaged. Does that tell me anything? Wiring or connectors rather than sensors maybe?
Its a real pain because its been wet here this week and AH is quite nice to have in these conditions on twisty back roads.
Old Nov 18, 2007 | 09:17 AM
ISeeRed's Avatar
ISeeRed
Just a side note to those who responded.....The steering wheel position sensor is actually in the steering rack and the AH system will actually "learn" the center position after a reset of the codes, so alignment cannot be the issue. I'm sure your far past that, but I thought I'd chime in. The plug for the connection is attached to the power steering cooling line in front of the ABS module.
Old Nov 18, 2007 | 04:11 PM
DeeGee's Avatar
DeeGee
I may try to clean that one up as well. I also thought about maybe taking off the kick panel and tring some electrical cleaner on the sensor.
Thanks.
Old Nov 18, 2007 | 06:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ISEERED
The Steering Wheel Position Sensor (SWPS) (which is also called " High Resolution Steering Wheel Position Sensor" Part# 38 in the 02 service manual Legend and 27 in the 98 service manual and is located on the lower end of the steering column near the fire wall. The ONLY electrical connection on the steering rack is the connection for the MAGNASTEER component. MAGNASTEER controls the feel of the steering wheel during various vehicle speeds.
The SWPS is a VERY precise resistor sensor and if it doesn't produce the correct outputs, the electrical signals to the EBTCM will be corrupt and do very strange things. There are TWO other sensors that contribute to the EBTCM's operation. The Lateral and Yaw Rate Accelerometer.
DeeGee
Do you have access to or can you have someone read the STEERING WHEEL POSITION SENSOR (SWPS) and the Accelerometers with a GM Tech II.
If it were me, I would insert two wires into the phase A and Phase B outputs of the SWPS and examine their outputs through a couple 90 degree steering wheel rotations.
BC
Old Nov 18, 2007 | 09:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Bill is the expert but will throw my 2 cents worth in. Mine went bad quite a few years ago. It would trip whenever going over speed-bumps and other similar places. Finally had the dealer replace it and no problems since.
Old Nov 19, 2007 | 03:23 PM
DeeGee's Avatar
DeeGee
That sounds just like the problem I have. maybe I'm trying to diagnose it to death
Bill, I'm afraid I don't have access to a Tech II. maybe I should stop being a cheapskate and shell out some $$
I guess its obvious by now that I'm not looking forward to replacing the sensor
Old Apr 27, 2008 | 09:41 PM
TVSGOTVETTE's Avatar
TVSGOTVETTE
I am getting the same C1287H code on my 04 coupe with 29,000 miles on the original Goodyears, could it be related to tire wear? I am planning on installing new tires in the next few weeks and also doing a 4-wheel alignment.
Old Apr 27, 2008 | 10:00 PM
TVSGOTVETTE
Default Annoying AH Problem
DEE GEE & Black Z06 or ANYONE WHO HAS INFO!
I have a 2004 coupe experiencing the same problems with the DIC setting the C1287 H Code. It happens when I'm on the turnpike and usually going straight at highway speeds and the roads are rather smooth. I have around 29,000 miles on the original Good Years. I am looking at putting on new tires in the next several weeks along with a 4-wheel alignment. The tires are noisy and the fronts are cupped some but pretty much standard for what I have seen for the C5. Could this be causing the problem? I am thinking about doing this before I take to my mechanic for any repair.
Old Apr 27, 2008 | 10:04 PM
BlackZ06's Avatar
BlackZ06
It is "possible" that bad tires or alignment is causing the code .... so obviously go ahead and have the tires replaced and the alignment checked/adjusted.
If the codes continue to appear after the service work ... post again with the specific codes and people here on the forum can help you in diagnosing/fixing the problem
Old Apr 27, 2008 | 10:11 PM
  #33
TVSGOTVETTE
Black Z06
Thanks will do! Tires still have decent tread and a few more miles in them but I would like to get the problem fixed before the real good cruising weather get here...
Old May 8, 2008 | 04:14 PM
  #34
Bluefire's Avatar
Bluefire
Default Calling DeeGee...
Did you ever get to the bottom of your C1287H code. My 03 Coupe is experiencing the exact same problem under the exact same conditions. Did you ever replace the SWPS? I would love to hear how you resolved it.
Old May 8, 2008 | 11:57 PM
  #35
DeeGee's Avatar
DeeGee
I've been lazy I'm afraid. I still have the problem although its intermittent and I can live with it most of the time. I cleaned up the connectors at the hubs and it seemed to improve for a while. It seems to be related to the brakes. If I brake very gently I get a little chatter and shortly afterwards I'll get a series of AH captions before it trips. That said, live TVSGOTVETTE, I've had trips without any braking at all so I'm not convinced. My tires are fine and I'd say the alignment is OK.
I'm coming up for a brake pad change. I'm going to do that before I do anything. I also thought I'd spray some electronics cleaner on the SWPS to see if it may be a dirty contact. A long shot but it costs nothing.
If all else fails I'll probably have a go at replacing the sensor.
Old Jun 11, 2008 | 10:13 AM
  #36
TVSGOTVETTE
I had the famous 1287H code and only 29,000 miles on an 04, took it to a Corvette Mechanic and he trouble shooted and replaced the steering wheel sensor. $75. part and 4 to 5 hours labor. Running great in Tulsa, OK! After the repair installed a new set of Michelin's and WOW what a difference!
