TECHRON use
Old Aug 24, 2007 | 07:43 AM
Sonny71's Avatar
Sonny71
Oldtimer
Default TECHRON use
Anyone out there know how often you can use the 20 oz bottle of Techron-like every other tank-full. Also does it cause any type of a chemical reaction if left in the tank over a month. I've sent the questions to Chevron but no reply as of yet.
Thanks,
Sonny
Old Aug 24, 2007 | 07:46 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I use a bottle once per season and have never had a fuel gauge issue........don't know if using more often would harm anything or be of any more benefit.
Old Aug 24, 2007 | 08:29 AM
R Devil's Avatar
R Devil
I won't bore you with my gauge/shiphon pump ongoing problem but as a last ditch effort to avoid replacing the sensors, I double dosed a tankful of Shell 93 octane. That was two tankfuls ago and both the gauge and shiphon pump are working.
I plan to use a 12oz bottle every other tankful in the future.
Old Aug 24, 2007 | 09:36 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Make sure you get the Techron PLUS. It has a specific additive to clean sulpher deposits from fuel level sending units, which is the exact issue that causes erratic fuel gauges in our cars.
I normally run a bottle through w/ each oil change. Up unitl May I'd been using the standard Techron. Then, on the way to Cruise-In my fuel gauge went truly nuts. It would read 1/2 tank when the tank was full and vary between reading correctly and below 1/2 tank then to empty w/ a CEL then back.
When i got home I got the new techron per a recomendation on here as a last ditch effort before replacing the sending units. I used 2 bottles in one tank, then one bottle in the next and it cured the issues.
I will now use Techron Plus.
Old Aug 24, 2007 | 11:31 AM
timemender's Avatar
timemender
Originally Posted by Cobra4B
Make sure you get the Techron PLUS. It has a specific additive to clean sulpher deposits from fuel level sending units, which is the exact issue that causes erratic fuel gauges in our cars.I normally run a bottle through w/ each oil change. Up unitl May I'd been using the standard Techron. Then, on the way to Cruise-In my fuel gauge went truly nuts. It would read 1/2 tank when the tank was full and vary between reading correctly and below 1/2 tank then to empty w/ a CEL then back.
I didn't know that. Thanks for the info!!!!!
Old Aug 24, 2007 | 11:32 AM
Cobra4B's Avatar
Cobra4B
^ NP... it even says so on the bottle
Old Aug 24, 2007 | 01:09 PM
David426's Avatar
David426
I use a bottle every 3-4 months.. No fuel gauge problems
Old Aug 24, 2007 | 02:42 PM
trussme's Avatar
trussme
20 gal. Techron Plus...every 3rd fill up..approx every 1000 miles.
Old Aug 24, 2007 | 03:56 PM
DeeGee's Avatar
DeeGee
I had a gauge problem over a year ago and ran 2 bottles through
No problem since.
Old Aug 24, 2007 | 05:02 PM
rcknusa's Avatar
rcknusa
You can use a bottle in every tank without damage, I just do not know exactly why you would want too. Everyother is good.
Old Aug 24, 2007 | 06:30 PM
nlreb54's Avatar
nlreb54
I use one in each of the two fillups just before my oil change. It really turns my oil dark. Anyone else have this happen?
Old Aug 24, 2007 | 06:52 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I use only Chevron 93 and now Texaco, since both have Techron blended in and have never had a guage problem.
To TECHRON use
