Battery Question
Old Aug 25, 2007 | 03:11 PM
DirteeDave's Avatar
DirteeDave
Default Battery Question
I'm getting ready to go on a 10 day vacation and am a little paranoid about what condition my battery may be in when I get back. The car is 37 months old with the original battery. Car is a daily driver and rarely goes more than 1 or 2 days without being driven. No issues with the battery to date. Should I even worry about this or should I consider using a battery tender while I'm gone?
Old Aug 25, 2007 | 04:23 PM
c4cruiser's Avatar
c4cruiser
For 10 days, you should be OK assuming you've not had battery issues before. You can always disconnect the negative battery cable. You will just have to re-program the radio presets (and maybe won't even have to do that!).
If there is a Harbor Freight store near you, their little battery maintainer works fine and they run around $7-8 when on sale.
Old Aug 25, 2007 | 04:26 PM
DeeGee's Avatar
DeeGee
10 days should be OK if its a DD and the battery is charged. A battery tender is good investment in any case.
Old Aug 25, 2007 | 04:30 PM
DirteeDave's Avatar
DirteeDave
Assuming I was to use a battery tender, what would be a good grounding source for the negative cable?
Old Aug 25, 2007 | 04:31 PM
LoneStarFRC's Avatar
LoneStarFRC
As the others here have stated, you should be OK as long as you don't already have a marginal battery to begin with. On a couple occasions I've left mine in the airport parking garage for a week at a time w/o trouble at all. Mine's a red top.
Old Aug 25, 2007 | 04:32 PM
DeeGee's Avatar
DeeGee
I hook mine up to both terminals but you can ground out on the block or theres a ground behind the pax headlight
Old Aug 25, 2007 | 04:40 PM
DirteeDave's Avatar
DirteeDave
Thanks guys, appreciate the help.
Old Aug 25, 2007 | 04:51 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You might want to pro actively replace the battery anyway. Often when they go it "BAM!" and nothing works. I learned the hard way!
To Battery Question
