Radio Loc code
Old Aug 27, 2007 | 08:00 PM
Pappa's Avatar
Pappa
8th Gear
Default Radio Loc code
Disconnected battery now Radio has loc code. Local dealer wants $35 to $65 to get me the code. Is there any other way?
Old Aug 27, 2007 | 08:05 PM
rob-cyn's Avatar
rob-cyn
Call another dealer, mine did it free.
Old Aug 27, 2007 | 08:12 PM
65GGvert's Avatar
65GGvert
If you'll search radio lock code, you can find instructions to do it without the dealer's help
Old Aug 27, 2007 | 08:32 PM
C5 Dude's Avatar
C5 Dude
Yeah, search in the forum for radio loc. I did and it works! One phone call and you will be back in business! It scared me to death when I changed my battery, but with the help of the forum "how to", 10 minutes later I had my radio back! Best of all......it did not cost a thing!
Old Aug 27, 2007 | 08:40 PM
ILM-Express's Avatar
ILM-Express
MFIC
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere). Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05 07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code. Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due).
Old Aug 27, 2007 | 09:04 PM
Pappa's Avatar
Pappa
8th Gear
Thank You very much The corvette forum is awsome
Old Sep 12, 2008 | 02:54 PM
VeroWing's Avatar
VeroWing
Thanks, I just found this doing a search and used it. My radios' working again, and I didn't have to pay a dealer. Thanks again. Mike
Old Mar 1, 2009 | 03:15 PM
park83's Avatar
park83
Entering 139010# did not work for me when I tried this. It just said "Invalid Account number"
Any ideas?
Old Mar 1, 2009 | 03:23 PM
SkyWarp's Avatar
SkyWarp
Old Mar 7, 2009 | 08:07 PM
jeffp1167's Avatar
jeffp1167
http://www.automotiveforums.com/t448806.html
here use this account number and like how he says. just used it on my camaro today and it worked
Old Mar 8, 2009 | 07:24 AM
Freestyler's Avatar
Freestyler
the 139010 or other codes dont work anymore...
whats the new code?
thanks
Old Mar 8, 2009 | 01:11 PM
jeffp1167's Avatar
jeffp1167
whats the new code?
thanks
use 106010 followed by the # key. that worked on my camaro's theftlock yesterday
Old Apr 5, 2009 | 05:24 PM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
I replaced my battery today and now the radio is locked. The codes listed do not work. Anyone have a code that does?
Thanks in advance.
Old Apr 22, 2009 | 05:42 PM
vetteboy666's Avatar
vetteboy666
hey anyone ever left the key in the on position for an hour instead of driving? Weather still sucks here and dont want to wait an hour while driving with no radio to fix it. My battery is fine so the parking lights on for an hour wont hurt it....
Old Apr 23, 2009 | 09:24 AM
vetteboy666
Default worked
Just leaving key in on position worked. Cant imagine driving for an hour without my ipod or radio........
Old Mar 9, 2010 | 08:33 PM
mgaddis0816's Avatar
mgaddis0816
1st Gear
Default Worked like a charm!
Originally Posted by SkyWarp
206053
I traded in my 99 Coupe back in December for an 02 Convertible. I removed the battery for the remainder of the winter and when I put it in this weekend I discovered that the previous owner had the Theftlock activated. I searched "C5 Radio Locked" and it brought me here. The process took me 2 minutes tops. Dealer was going to charge me $40-$80!!! Thanks!
To Radio Loc code
