Does exhaust volume equal power?
Old Aug 29, 2007 | 07:06 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Does exhaust volume equal power?
I just switched my Vararam out for a K&N FIPK.......... I know, I know it kills me to do it because I have had every intake on the market and times at the strip have shown the VR to be king period.
HOWEVER my car is getting a tigershark front and I can not use the VR soooooo I got the K&N and drilled some holes in the shroud under the filter. The exhaust tone seems a little more subdued now and when I shift at 3.5k it used to give a little pop (like a very small backfire sound) but does not do it anymore.
My questions are
1) does the decrease in exhaust volume mean my car is not breathing as well and I am not getting all I can out of the car?
2) does the lack of this small pop between shifts show that the airflow coming in is smoother and is not causing a hiccup?
Old Aug 29, 2007 | 11:42 PM
0Cajun @ Edgyvette
Former Vendor
ttt...................
Old Aug 30, 2007 | 09:13 AM
99 vett babycar's Avatar
99 vett babycar
only in an F105
Old Aug 30, 2007 | 09:43 AM
0Cajun @ Edgyvette
Former Vendor
Originally Posted by 99 vett babycar
only in an F105
Do you mean F150? So the fact that the car is quieter has nothing to do with the air intake volume? Thanks
Cajun
Old Aug 30, 2007 | 11:03 AM
EStreeter's Avatar
EStreeter
LOUD does not equal POWER
Its pretty embarrassing when you learn that the hardway some evening on the street - especially if your girl is in the car with you. NOT
I've noticed that there are some Mustang GTs running around with a nice exhaust sound but they are wimps when it comes to power.
When you said "volume" I assume you meant loudness and not the amount of exhaust flow. Higher flow does mean more power because it lets the engine breathe better. More air = More Power.
Old Aug 30, 2007 | 01:20 PM
0Cajun @ Edgyvette
Former Vendor
My first post may not have been clear. Here is the deal, I changed air intakes from VR to FIPK with no other mods done to the car it is quieter now. Does this mean I have less airflow than when using the VR? Thanks
Cajun
Old Aug 30, 2007 | 01:48 PM
Higgs Boson's Avatar
Higgs Boson
Not necessarily. Simple things like bends, material used, length, etc can change tone and volume. I seriously doubt there is a difference in flow enough to alter power or AF ratios by any meaningful amount.
Old Aug 30, 2007 | 02:21 PM
AU N EGL's Avatar
AU N EGL
In takes add some power, but not much. Real CAI are all about the same.
LT headers, and free flowing exhaust also help.
Doing a Dyno tune even to a stock car will provide a huge benefit
Now, PP heads and a great cam, look out
To Does exhaust volume equal power?
