MAF question
Old Sep 3, 2007 | 04:28 PM
Bob CTS's Avatar
Bob CTS
Default MAF question
Here is a good one, I have on occasion gotten the SEL and it indicates a rich condition in Bank 1 & 2, the car originally had a Vararam installed but I put the stock air box back in. Today I was looking for leaks and looked at the MAF and (2.4 9.6 LS1 +5%) is engraved in the side by the connector, looks like where the barcode was, but it has been removed. Just looking to see, this is mind boggling.
2002 Z06 37K miles on it. No screen on it. The LS1 is what is weird.
Bob
Old Sep 3, 2007 | 05:21 PM
rws.1's Avatar
rws.1
I sounds like it is an aftermarket MAF. Designed to run on different Air/Fuel tables.
Perhaps to compensate for the lean running Vararam.
Maybe that is why it is now running rich....
I am only speculating...
Perhaps someone on the Board knows....
bump for you....
Old Sep 3, 2007 | 09:54 PM
Bob CTS's Avatar
Bob CTS
bump for you....
That is what I am starting to think also, I think I might 'disable' this thing and let GMPP replace it, I got the rich codes on the way home tonight.
Old Sep 4, 2007 | 01:46 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I think that someone has re-calibrated the MAF table to compensate either for an aftermarket MAF or for the Vararam-- The #'s do have some correlation to the HZ MAF table--Idle is generally between 2400 HZ ( the 2.4 ) and 2800 HZ ---and WOT it is generally between 9000 HZ and 10000 HZ ( the 9.6)----- And they probably added 5% globally beween these 2 #'s---I would put a Stock MAF back in it and download the stock MAF table back in----The stock MAF is good for 500 RWHP-
Old Sep 4, 2007 | 08:20 AM
Bob CTS's Avatar
Bob CTS
Thanks, if GM replaces the MAF can they set the MAF tables back to stock?
Bob
Old Sep 4, 2007 | 12:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like your PCM has been tuned. If so, most of the time it is for the better. If GM does anything with the PCM, they will reflash the entire thing back to OEM Stock. That could be good or bad. What modifications does your car have now. If for instance you have an aftermarket CAM installed, reflashing it back to stock might cause driveability issues.
Why did you remove the VARARAM?
Bill
Old Sep 4, 2007 | 01:18 PM
Bob CTS's Avatar
Bob CTS
Bill
Engine is stock as well as every thing else. That is why I am not too woried about resetting the PCM. As for removing the vararam, I did not care for it.
Old Sep 4, 2007 | 09:39 PM
SJByrne's Avatar
SJByrne
Best of luck trying to get GM to warranty a de-screened MAF. They wouldn't do it for me. The only stock MAF without a screen is the '04 Z06.
Old Sep 4, 2007 | 10:05 PM
Bob CTS's Avatar
Bob CTS
The 02 does not have a screen:
Corvette Museum 02 LS6 specs
Old Sep 4, 2007 | 10:13 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Correct. 2001 was the only year the Z06 had a MAF screen. The 02-04 did not.
Old Sep 5, 2007 | 12:05 AM
SJByrne's Avatar
SJByrne
I stand corrected :o Going by what the dealer told me. Maybe they were refering to my model year only.
To MAF question
