Headlight problem and starting problem. Related?
The other problem may or not be related. Sometimes when I turn the key to start it nothing happens. If I do it enough times it will eventually start. I tried a different key in suspicion that it might be the resistor but that one does it too.
Is it an older model with an OEM battery? If so, it could be your battery on the way out. Thats where I'd start.
If the battery's good I'd leave TS turned off and see if the problem is still there on manual headlights. If so, it may be the turn switch. With TS engaged it should cut out the stalk switch from the process.
Good thing it a manual!Here are the possible problem areas in order of which you should investigate:
Battery connections. Must be clean, tight and the cable bolts MUST BE torqued to 11 ft/lbs.
Clutch Safety Switch. (if you have a manual) press the clutch fully to the floor and then let it up 2". Listen in the passengers foot well for a relay clicking. If you hear the relay, the switch is most likely working.
Theft Deterrent Relay (TDR) Thats the relay in the passengers foot well that the clutch switch makes click. The TDR is the actual relay that is connected to the starter solenoid that makes the starter solenoid work. If it clicks , the high current contacts inside the relay could also be burnt and not allow the high current necessary for the solenoid to work through. That would prevent the starter solenoid from making contact and operate and spin the starter until until the contacts inside the relay heats up enough to allow the solenoid to work.
You can access the TDR relay in the passengers foot well behind the toe board. Its above the BCM. It has FOUR wires: a fat RED, fat PURPLE, a yellow and a yellow/black wire. The fat red is 12 VDC and the purple wire is the wire going to the starter solenoid. The relay is inexpensive and a good place to start! Thats what I think is going bad on my car.
Loose starter connections. VERY COMMON ISSUE!!! Loose wires on the starter and solenoid will cause this issue! If there loose, it will eventually cause the wire and solenoid to burn up! (get crispy) Then it will FAIL!
Starter solenoid. If the TDR isn't bad, then the solenoid is probably bad If it fails to start and trying the ignition switch a few times doesn't work and your stuck, whack the starter with a hammer or a wrench.
Starter. If the brushes inside the starter are worn or the commentator ring is corroded or burnt, the same mechanical agitation will also alleviate that issue (temporarily)
Bill C
Since your battery is fairly new, you might check your connections.
Joe B.
Finally I changed the battery with a NAPA Orbital (Same as Optima but all black, OEM look) and all my problems gone away.
They use this tester
http://www.etoolcart.com/browseprodu...TMCR500XL.HTML
To do a real test, you must do a load test. Almost any place that sells batteries will do it for free. Take the car back to where you bought the battery for testing.
It is not unusual for new AGM batteries to go bad.
I have seen battery load testers for $20 !
