I need HELP!!!!!!
Old Sep 5, 2007 | 09:40 PM
Slick Rick's Avatar
Slick Rick
Default I need HELP!!!!!!
Heres the story. I get the 97 up on jacks to change the oil. Have every thing ready to go and notice that the oil pan plug is all messed up. This is my first oil change with the car. I just bought it 6 months ago. I cant get any kind of wrench on it. No problem Ill run over to the dealer and get a new plug. Get the new plug get home get the old vice grips out and cant get the plug to budge. So I get a water pipe wrench get it on there put all 180 lbs into it and it still wont budge. Now the bolt is really gunked up from both vice grips and the pipe wrench and the plug still wont budge. What do you guys suggest. I have atrip planned this weekend and Ill have to cancel if I cant get it fixed tomarrow. Thanks Rick
Old Sep 5, 2007 | 09:46 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Sounds like someone used an impact wrench on it. Might have to do the same to get it off. Just be careful not to snap the head of the bolt off or you'll have to drill it out and retap the pan.
Old Sep 5, 2007 | 09:54 PM
vettenuts's Avatar
vettenuts
Really hate to ask, but are you are going the correct way to loosen? Sometimes when under the car I get turned around on direction and need a ratchet to ensure things are going "lefty-loosey" by setting the wrench first. On the oil plug, since a ratchet won't fit due to the front cross-member I have started using the ratcheting box end for this very reason.
Old Sep 5, 2007 | 10:30 PM
Slick Rick's Avatar
Slick Rick
Nope I was going the right direction. I just cant get it to break loose I used penitrating oil and it still wont break loose. I guess Ill have to go toa shop where they can put it on a rack and get to it a lot easier maybe have to use an easy out or somthing.
Old Sep 6, 2007 | 02:24 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Take a propane torch and get it nice and hot and it will come loose.
Old Sep 6, 2007 | 02:35 AM
utryd2's Avatar
utryd2
That will do it......but dont use an impact wrench......get a good socket that will not strip loose and a good long breaker bar, and turn slowly.....
Old Sep 6, 2007 | 03:00 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default propane torch!
Be Careful, the oil pan is all aluminum and it doesn't like propane torches!
Old Sep 6, 2007 | 05:33 AM
vettenuts's Avatar
vettenuts
I think Sears makes sockets for those times that the head is rounded, not sure if you can get in there though.
Old Sep 6, 2007 | 10:34 AM
Slick Rick's Avatar
Slick Rick
You are correct, cant use heat on it, it is aluminum. I guess im gonna run it down to the local shop and see if he cant break it loose.
Old Sep 6, 2007 | 11:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES YOU CAN USE HEAT!!! You want to heat JUST THE OIL PAN and only enough to get it to around 250-275 degrees. Heating the pan will get it to expand and the plug should remain cool. That should allow the plug to come out easier. DO NOT heat the pan till it cherry RED, yep,,,thats a BAD idea!
Old Sep 6, 2007 | 01:03 PM
Slick Rick's Avatar
Slick Rick
Taken Care of. Thanks for the help guys........
Old Sep 6, 2007 | 01:20 PM
bighank's Avatar
bighank
Default And Call The Fire Deparatment Too
After the blaze you will need a lot more than a new oil plug. BIGHANK
Old Sep 6, 2007 | 04:41 PM
vettenuts's Avatar
vettenuts
Well, what happened?
Old Sep 6, 2007 | 06:11 PM
Slick Rick's Avatar
Slick Rick
Took it down to the local shop. The owner of the shop owns a 2000 C5. Put up on the hoist took some vice grips and a 4 ft breaking bar and wa-la broke loose. I brought my own oil and filter and a new drain plug, and 30 bucks and an hour later I was back on the road. I love mom and pop shops........
Old Sep 6, 2007 | 06:15 PM
Slick Rick's Avatar
Slick Rick
It figures get the oil changed and now the oil pressure sensor took a dump. Second time in 3 mos. Thats covered though as the dealership I bought it from had to replace it before I would buy the car from them, and now there gonna have to replace it again. Talked to them today and they said its on them.........
Old Sep 6, 2007 | 09:14 PM
stingraymyway
Glad to hear that! Most dealers don't want to handle problems, just sell you something you don't need.
Old Sep 6, 2007 | 09:20 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sweet glad to hear a success story and not a disaster story!
I know you wont over tighten the plug
Thanks,Matt
To I need HELP!!!!!!
