Cleaning the engine compartment
Old Sep 7, 2007 | 01:32 AM
RoccoC5's Avatar
RoccoC5
Default Cleaning the engine compartment
Can anyone offer any advice on cleaning the engine compartment? Anything I need to watch out for? Is it safe to go at it with a hose and a wash mitt? Seems to me I've read posts where water caused electrical problems...
Old Sep 7, 2007 | 10:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The problem with hosing off your engine is that the KNOCK SENSORS (there are TWO) are located under the intake manifold. Each sensor sits inside a shallow well on the valve valley close out plate. The rubber seals that are suppose to seal the wells do NOT seal very well and those wells will get water in them. This will destroy the sensors and you will get Knock Sensor DTC's.
I just wipe the engine down with simple green and a rag and then wipe the engine down with WD-40. It cleans up nicely!
BC
Old Sep 7, 2007 | 11:11 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Check this out
File Type: pdf
Old Sep 7, 2007 | 11:43 AM
EStreeter's Avatar
EStreeter
Originally Posted by Todd157k
Check this out
Does that look like a Corvette to you?
Old Sep 7, 2007 | 02:50 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I'm so sorry. I didn't realize dirt in an engine compartment is so totally different with different cars. My bad. Thanks for the correction.
See, if you'd learn to read, you'd see that you don't use high pressure to wash off the engine therefore elevating (word to big for you?) the problems Bill is talking about.
Old Sep 7, 2007 | 03:09 PM
jirasvet's Avatar
jirasvet
Old Sep 7, 2007 | 03:51 PM
Oldvetter's Avatar
Oldvetter
DO NOT use Simple Green, it attacks aluminum.
Old Sep 7, 2007 | 09:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It works VERY WELL on plastics! WD-40 will dislove any dirt or grease on aluminum.
BC
Old Sep 7, 2007 | 10:21 PM
kevin40zx's Avatar
kevin40zx
I use soapy water and a rag. No problems and engine looks fine. Definetly not a good a good idea to use the hose.
Old Sep 7, 2007 | 10:47 PM
2MFFZo6's Avatar
2MFFZo6
The least amount of harsh chemicals the better. Dont ever use gunk on your corvette......please. Chemicals will discolor everything and your motor wont look good unless you have a gallon of armor all on it. Use car wash soap and a rag then you can blow dry with a leaf blower so it doesnt water spot.
t
Old Sep 8, 2007 | 10:05 AM
jrose7004's Avatar
jrose7004
Old Sep 8, 2007 | 10:46 AM
TEXHAWK0's Avatar
TEXHAWK0
I use a paint brush to brush away loose dirt, then just wipe down with a damp paper towel. You could blow away loose dirt with compressed air, then wipe down.
To Cleaning the engine compartment
