Oil Pressure Switch Question
Sep 10, 2007 | 09:48 PM
I need to change my oil pressure switch. Do I need to drain my coolant before I remove the intake manifold? Thanks Rick
Sep 10, 2007 | 11:17 PM
No, search for procedures. You only have to slide the manifold forward a little.
Do clean the connector of any oil and use only 15 ft-lbs torque or you will be replacing it again. Some people think NAPA's part is better than GM's.
Sep 11, 2007 | 02:48 AM
As for re-torquing the manifold follow the instructions at the bottom page of this website.
http://www.ls1howto.com/index.php?article=5
If you don't have an inch pound torque wrench it is very handy to have. They run about $50 bucks.
Sep 11, 2007 | 04:49 PM
Sep 11, 2007 | 05:31 PM
Quote:
Originally Posted by
MattB
Nice little write up if you haven't worked on a modern car before.
