Bypassing A/C
Old Sep 11, 2007 | 09:30 AM
11sec_C5Z51's Avatar
11sec_C5Z51
Default Bypassing A/C
My A/C went out and instead of getting it fixed, I just want to bypass it. I don't use my AC anyway. How do I go about bypassing the AC? would I have to get a shorter belt?
Old Sep 11, 2007 | 09:56 AM
myk7's Avatar
myk7
Nope, just take the AC belt off. There are only 2 belts on the car, the AC belt is the "inner" belt.
Old Sep 11, 2007 | 10:58 AM
11sec_C5Z51
How hard is it to take off?
Old Sep 11, 2007 | 12:47 PM
myk7's Avatar
myk7
It's very easy after you have done it a couple of times. Both belts have tensioner pulleys. I use a rachet and socket to move the tensioner pulley to take tension off the belt and then slip the belt off the pulley. Be sure to note how the front belt is run before you take it off. It should be a 3 minute job if everything goes well.
Old Sep 11, 2007 | 12:52 PM
timemender's Avatar
timemender
Just cut it off if you have no intention to save the belt. You can always buy a new belt. Be careful - don't cut the wrong belt!
Old Sep 11, 2007 | 12:57 PM
peebee_c5's Avatar
peebee_c5
Exactly. Doesn't get any easier than that.
Old Sep 11, 2007 | 04:52 PM
11sec_C5Z51
is there anymore power to be had with the removal of the A/C belt.
Old Sep 11, 2007 | 06:48 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
The A/C compressor is disengaged when you go to wide open throttle to reduce drag. Without a belt there would be a slight increase in available HP but nothing you would notice.
To Bypassing A/C
