Throttle Body Butterfly
Old Sep 13, 2007 | 12:52 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default Throttle Body Butterfly
Advice Please!
Some time ago I purchased a ported a TB from a Forum Member. Have not installed it, because I noticed a small gap, perhaps 1-2mm, between the top butterfly plate, and the top of the TB. Is this normal, or was there a mistake made in porting the top side of the TB (perhaps with too much enthusiasm?
However, if the butterfly plate was ground down, and that gap should not exist, I guess I can always use the plate presently in my current TB.
Thanks for any info.
Regards, GRT
Old Sep 13, 2007 | 01:44 PM
EStreeter's Avatar
EStreeter
The plate and the area around the plate are not usually touched in a porting job but after the TB is ported, you can see the gap between the throat and the plate becuase of the material removed in front and behind the plate. This is normal. If you push the plate vertical it should completely close the opening and make a seal against the TB.
The electronic controls will move the plate to a position to control air flow for the correct idle setting.
Install it a see how it runs.
Old Sep 13, 2007 | 03:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
In a NON powered up scenario, the plate will NOT be completely shut! The PCM and TAC module tell the TB blade what position to go to. It will spring open slightly when theres no position signal to it. Sounds normal to me.
BC
Old Sep 14, 2007 | 12:33 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
BC
Old Sep 15, 2007 | 09:20 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Originally Posted by Cajundude
Hi Cajundude.
You posted an "I agree flag after "EStreeter & Bill Curlee's" input about my question. I does merit a thank you note.
http://forums.corvetteforum.com/show...post1561898600
Regards, GRT
Old Sep 15, 2007 | 10:58 PM
Cajundude's Avatar
Cajundude
Now I remember.
Jason
To Throttle Body Butterfly
