hood noise possibly
Old Sep 13, 2007 | 06:49 PM
corvette19942003's Avatar
corvette19942003
Default hood noise possibly
Hey guys. Ive got a 98 coupe. I hear noise when at low speed when going over bumps. it seems to go away when im cruising. It sounded like the air dam i thought, but it is tight. I noticed the hood seems to shake a lot at low speeds to so i adjusted it int the rear, i have maximum upward pressure with the adjustable screws. I checked under the hood and everything seems tight as far as i can tell. Does anyone else hear this noise too. I did a search with no results.
Old Sep 13, 2007 | 07:54 PM
jirasvet's Avatar
jirasvet
Do not have noise but found this:
"Suspension squeaking
In cold weather you may hear the suspension creak when you go over speed bumps. To fix this, clean (optional) and lubricate the sway bar bushings. The adjustable metal sway bar end links on Hotchkis and T1 bars can also create loud clicking sounds. Most adjustable end links are quiet initially, but wear out and get noisy over time. Greasing and protecting the end links from dirt may prevent wear."
