Help Changing Fuel Filter
Old Sep 14, 2007 | 10:56 PM
grunz95's Avatar
grunz95
Default Help Changing Fuel Filter
I have a 99 coupe. I purchased the filter from the dealer which has the built in fuel regulator. Is there anything I need to do special to replace the filter.
Thanks In Advance.
Gary
Old Sep 14, 2007 | 11:08 PM
Showdown's Avatar
Showdown
I let "quick lube" change mine for 30 bucks.
Old Sep 15, 2007 | 12:17 AM
u4ick's Avatar
u4ick
I was told that ther is a tool that helps get the fuel lines off and makes the swap easy.
Old Sep 15, 2007 | 12:24 AM
LoneStarFRC's Avatar
LoneStarFRC
Thanks In Advance.
Gary
Either let the car sit overnight to bleed off the fuel pressure or relieve the pressure up front at the fuel rail schrader valve. Go to any parts store and pick up a set of quick connect tools. The sets usually have all the sizes from 1/4" to 1/2" (or 3/4"). You'll need one to release one quick connection fittings on the old filter. The other two are squeeze and release types, no tool necessary. Lastly, I would recommend you put a drop of clean engine oil on each nipple on the filter just prior to re-connecting them to the fuel lines. There are o-rings inside that should have a little lube to ensure a good connection.
Pretty easy job really. A little messy from some of the spilled fuel that's going to happen, but hey just keep some clean rags nearby and your good to go.
HTH
To Help Changing Fuel Filter
