ac problems
Old Sep 15, 2007 | 12:32 PM
ROMARNV's Avatar
ROMARNV
Default ac problems
my ac blows cold at idle, when i start moving it warms up. any ideas?
Old Sep 15, 2007 | 01:01 PM
rcknusa's Avatar
rcknusa
That is definetly a strange one. I have had other a/c problems but not that one. Is it hot on driver side and cold on the passenger side?
Old Sep 15, 2007 | 01:57 PM
tommyk's Avatar
tommyk
A/C might need to be recharged.
Old Sep 15, 2007 | 02:43 PM
Plasticfan's Avatar
Plasticfan
I would also recommend checking the AC chg level. The PCM senses pressure in the system and shuts off the compressor if it is not within spec. As RPM increases, the low side goes lower and the high side goes higher. Either condition could cause compressor shut down. To verify if that is the case, watch the compressor clutch rotate at idle, have a buddy press on the gas pedal and see if the clutch stops turning at some eng speed. HTH
Old Sep 15, 2007 | 05:51 PM
bestvettever's Avatar
bestvettever
Default May be air doors
Hi, A couple of possibilities causing your problem. Is your unit set to inside recirculate, or outdoor mix. In very hot weather a unit set to outside air will tend to blow less cold when car is in motion. If it is set to recirculate, and blows warmer when in motion, your air mixture doors may not be operating properly. Possible faulty vacumn line, actuator, or debris jamming the door open. One other remote possibility is a faulty heater valve, when you are in motion (more rpm's), putting more pressure on the coolant from the water pump, it may be forcing more hot water into the mix than the temp settings are calling for, more or less overriding the temp settings. You could check the refridgerant charge, but normally with a shortage of refridgerant you will blow colder as the rpm's increase, up to the point that there is not enough refridgerant to actuate the pressure sensors. Hope any of this helps
Good Luck
Old Sep 15, 2007 | 08:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the money!
BC
Old Sep 15, 2007 | 09:54 PM
Ron C!'s Avatar
Ron C!
Hmmm. Mine is doing the same thing, however it blows cold on the passenger side all of the time, but the drivers side is cold at an idle, then warms up when driving. Just installed a new compressor, orifice tube and filter, also a new control head. Weird, we checked the charge level and it is right on the specs. Mine does this when I first start it and seems to even out and work as it should, cold all of the time after driving for 25-20 minutes. I have been scratching my head over this one.
To ac problems
