Another Flip Tie Mod ??
Old Sep 21, 2007 | 05:30 PM
bALdWooKiE's Avatar
bALdWooKiE
Default Another Flip Tie Mod ??
I just recently did the flip tie mod and I must say the throttle response is amazing and I can notice the difference at higher speeds. So my question is has anyone dynoed there car with just this mod alone? Im hearing 10-14 rwhp ?
Old Sep 21, 2007 | 05:34 PM
vettencle's Avatar
vettencle
School me...What is a flip tie mod??
Old Sep 21, 2007 | 08:29 PM
KCJeff's Avatar
KCJeff
Flip tie mod info:
http://forums.corvetteforum.com/show....php?t=1561268
Old Sep 21, 2007 | 11:28 PM
d0cktor's Avatar
d0cktor
The link to Download the PDF isnt working.
Old Sep 22, 2007 | 01:04 AM
KCJeff's Avatar
KCJeff
Hmmm. I'm not sure why that link is no longer valid. I have the .pdf file on my hard drive. If you would like me to email it to you, just PM me with your email address. The file is 1.5mb (large), so be sure you have a high speed connection and/or that your ISP doesn't limit file sizes (sometimes the free services limit attachment sizes).
Old Sep 22, 2007 | 09:58 AM
Gordy M's Avatar
Gordy M
The Flip Tie mod will allow you use somewhat cooler air going to the engine. This is especially true a low speeds. Where this helps the most is hard acceleration at low to moderate speeds. Once you near top end speeds the IAT are closer to ambiant temps regardless of Flip Tie or stock. If you switch to a Cold Air system like Callaway, Ice Box or VeraRam you will have even colder air.
Old Sep 23, 2007 | 03:42 PM
dndrsn's Avatar
dndrsn
http://forums.corvetteforum.com/show....php?t=1820171
Old Sep 23, 2007 | 04:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is like the zip tie, just upside down. I highly doubt that it would yield 10 RWHP. IMHO
Old Sep 23, 2007 | 09:19 PM
Chevy Guy's Avatar
Chevy Guy
Unless you are running serious high RPM heads/cam this wont yield much of anything at all. The OE set up isn't as restrictive as CAI manufacturers would have you believe.
Old Feb 5, 2008 | 10:44 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Can you tell me how the Callaway Honker could give you even colder air than this mod?
Old Feb 6, 2008 | 06:21 AM
dndrsn's Avatar
dndrsn
I don't know, the air to the "FLIP-TIE" mod is coming from the same place as the Honker. Maybe Gordy M is referring to the Ziptie mod which is entirely different.
Old Feb 6, 2008 | 03:28 PM
Dave68's Avatar
Dave68
There must be some, since a simple Halltech intake swap yielded me about 12 RWHP. The other issue with the stock setup (except Z06s) is that the air being drawn into the intake is very warm (more so with headers). During slow-moving or stop & go driving, the engine bay temperature can soar up over 140F. When this happens, the ECU dials back ignition timing to avoid knocking (predetonation). You can easily lose 10 HP because of this.
The flip tie mod helps to keep the intake air temp close to that of outside temps, but it doesn't help keep engine electronics (like the EBCM), belts and hoses from being exposed to that scorching engine bay heat.
This is why my cold air mod channels outside air at and past the intake filter to both cool off the air being ingested by the intake AND to keep the engine bay at decent temps. Z06s do something similar, although not as directly as my scoop mod.
You can see how I did it (and look at a few more DIYs) here:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Old Feb 11, 2021 | 11:25 PM
maxgee's Avatar
maxgee
Default Old I know, but..
I am going to do a comparison of the fliptie vs ziptie mod.
To Another Flip Tie Mod ??
