I've read where these sensors sometimes break off. In addition to inaccurate torque, I was wondering if this breakage could be caused by wheel imbalance (vibration). Relatedly, I was wondering if a dab of silicon adhesive (or whatever), under the sensor body, might add some insurance against this breakage?
I have had this discussion with "oldvetter" in the past, as my manual is the same. I "think" there is a TSP on the sensors for air leaks. GM may have changed the torque value as a result. You may want to research this further.
That would explain the two different settings. Thanks.
I can't find the TSB ... but I went to the Schrader-Bridgeport site (they make the sensors for most OEM systems) and using a 2002 Corvette as an example, they list the torque as 62 in/lbs (7 N/m) so looks like there must have been an update after our manuals were published.
As far as I can tell they are. There are other makers of TPMS systems such as TRW Automotive, Denso, Siemens VDO, and Johnson Controls. The Schrader site was the only one that gave useful information specifically about the Corvette, and even recognized that there are 3 different sensors for the Corvette (2 for the C5 and one for the C6, including the GM part numbers), so I kinda suspect they are the OEM supplier, if not, they certainly know a lot about the system ....
