after headers install question...
Old Sep 26, 2007 | 02:37 PM
neokorros's Avatar
neokorros
Default after headers install question...
i received my headers in the mail this morning and i am wondering if after installing them if i HAVE to HAVE it dyno tuned asap.
i know i NEED to have it dyno tuned eventually for optimal performance but it is something i need to have done immediately?
will the car perform worse after installing headers if not tuned ?
i have a 2000 m6 with no mods except for k&n fipk intake and borla stingers.
the reason i am asking this is because i am saving for 3:90 gears also, and i will wait to have it all installed and tuned at the same time if i have to. but if i can install the headers with no performance loss or problems without tuning then i will install them and wait to tune till after i get my 3:90s.
thanks a bunch everyone
~ nick
Old Sep 26, 2007 | 03:23 PM
94legaleagle's Avatar
94legaleagle
How soon you planning on doing the gears?
You don't have to get it dyno-tuned RIGHT away simply cause you added headers, but you are probably going to get a few O2 sensor codes that you will have to keep deleting - no big deal
I think I drove about 1200 - 1500 miles or so after I installed my headers, but before I had it dyno-tuned and I didn't have any problems, other than an occassional code that I needed to clear.
Old Sep 26, 2007 | 05:27 PM
uracowman's Avatar
uracowman
a tune is not necessary just because of a header install,but without a tune,your engine won't run as efficiently.
If I were you thought,I would get the tune before the gears.
Old Sep 26, 2007 | 05:34 PM
rws.1's Avatar
rws.1
I ran mine for 3 months and 9K miles before I got a tune.
I did get those annoying P0420 P0430 (low catalytic converter efficiency) codes about 1x per week until I had them turned off.
Old Sep 26, 2007 | 05:39 PM
FASTBLACKLS6's Avatar
FASTBLACKLS6
St. Jude Donor '10
same thing here. Just the annoying check engine light. No performace problems
Old Sep 26, 2007 | 05:44 PM
neokorros's Avatar
neokorros
roger that. thanks guys for the input, i really appreciate it. i think i am going to head over to ECS in the next 2 weeks for a dynotune, and then have the gears thrown in there in a month or 2 down the road when i have enough funds saved for it.
~ nick
Old Sep 27, 2007 | 04:08 PM
88sk's Avatar
88sk
I gotta 2k 6spd. also,I put in heads,cam, borlas,intake etc.(borlas which I took off for ti's)mine ran fine,no codes , I took it to get tuned ,the only thing I noticed they did was raise the idle for $450 from the overrated board tuners here.
To after headers install question...
