Grinding noise
Old Sep 26, 2007 | 02:57 PM
Blacked-out's Avatar
Blacked-out
Default Grinding noise
I have a 1998 6-speed coupe. When I idle with the clutch in its OK, but when I apply the gas and let out the clutch I get the grinding. The clutch doesnt seem to go down further than before, I just get the terrible noise. I dont think I can handle the bleeding thing....any suggestions?
My situation doesnt sound as bad as the other posts, but I dont want it to get too bad.
Old Sep 26, 2007 | 07:16 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
So you are either grinding your clutch or the gears? If its the clutch, then its shot. If its the gears, start with a shifter alignment procedure which is pretty easy to do.
Old Sep 26, 2007 | 07:44 PM
hornet7's Avatar
hornet7
Default Procedure
Can any one help with this procedure?
Old Sep 27, 2007 | 11:18 AM
Blacked-out
Default Hmmmm
I've had my car for 6+ years and no issues with the clutch/drivetrain, can this shifter misalignment just start to act-up?
I only get this terrible sound when I add gas/disengage clutch.
idle (in gear or not) = OK
To Grinding noise
