Weird A/C issue...What could be the problem?
Old Sep 27, 2007 | 11:31 AM
97C5ENVY's Avatar
97C5ENVY
Default Weird A/C issue...What could be the problem?
First off let me say that i have "Dual Climate Control" and that i rarely use my A/C (probably gets used once a year for less then a hour). Anyway two weeks ago i used it for the first time in over a year and noticed that it wasn't blowing cold air (yes, the main thermostat was set at 60*). The wierd part is that when i turned the passenger side thermostat down all the way the passenger side vents blew cool air while the center/drvier side still blew ambient temp air.
Any idea what's going on and why? And better yet what can be done to fix it?
Old Sep 27, 2007 | 11:37 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sounds like the compressor may not have turned on. Did you check it to verify it was running? If it wasn't, take it to an AC shop.
Old Sep 27, 2007 | 11:47 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check for HVAC sytem DTC's, clear the codes and see if any come back. If they do, or the problem isnt corrected, pull and then replace HVAC fuses 15 & 26 to reset the HVAC controllers. I also recommend checking the charge on the system to see if it is low. If it is LOW, just recharge it and check for leaks.
To Weird A/C issue...What could be the problem?
