Hope I'm not stepping on any toe's posting this. But it clears up couple of questions for this sticky
The fitting for the block that Hemi426 handmade, a M16X1.5 X 1/8" can be purchased at ur local speed shop for $8. It's an AutoMeter part no. 2268, metric adaptor & has the crush washer included, the part for the Buick sensor can be found at Home Depot, it's a Watts
#A734, a double female, 1/4" X 1/8", about $2.75, which when using the oil line kit makes it easy to hook everything up together. Couple pics attached
Again, I was just trying to help w/info for those doing the relocate like me.
Just a quick thought... I did the relocation too, but used copper tubing. I am an Engineer and was looking at most of the available plastic tubing due to the fact its obviously easy to route as needed. Most of what I saw had fairly low maximum temperature capabilities then comparing those numbers to the highest possible oil temps for our cars...I didn't like what I saw. I decided that I didn't need that line melting on me driving down the freeway, so I went with copper and I've had no problems.
I have had a plastic line melt and once it starts leaking it is a big safety issue, oil everywhere and a big fire hazard. Be safe and use the copper line from the start.
Yep. Our cars can hit upwards of 300 Deg F if driven hard and even in normal traffic that I see out here in S. Calif. I see 217 Deg F all the time. The plastic lines can vary in temperature ratings from 100-180Deg F. I wouldn't want oil spraying all over either.
It turns out the General built in a safety feature for this kind of situation. The way it works is when the line melts and oil starts spraying, the engine seizes to keep a fire from starting.
I just used the Auto Meter along with the watts part & a 1/8 in close MM as I did not want the hose up top of the motor. I watched my last one fail on Thursday I had just changed my oil and cold start up my pressure reached 50 lbs then the gauge went crazy. I think the the heat expands the aluminum and ruins the seal. My wife has a 05 Bonneville and the oil pressure is always 50 - 60 lbs. So I hope this trick lasts.
Reason: change pics
I agree that the plastic tubing is very risky - and copper tubing is not that hard to work with. However, I prefer the "cut a hole in the shroud" method. It is simple and avoids the chance of leaks.
Yes, you can do that but many forum members were reporting fumes getting into the ventilation system afterwards. I tend to suspect as well that having a hole there where it wasn't meant to be isn't such a great idea with rain water pouring on top of things that wasn't meant for it either...GM designers wouldn't have put that plastic tray there for no reason, it has a specific purpose.
You seal up the hole when done. No fumes, no leaks, no problem. You will have problems if you leave the hole open. If GM had anticipated all the repairs, I suspect they would have installed a removable plug like they did for access to the pcm in the right wheel well.
The other thread is incredibly long and for good reason. It seems everyone is doing the Buick sensor mod. I want to use the Airtex unit for the Vette and mount it remotely. Can I just get the correct fittings for it, plus the oil line and use the Vette sending unit?
if i do the mod as shown in this set of pics, and pull the intake, will it still fit under the intake?
also, does it just screw in where the old sensor was?
thanks
Dang I'm learning something new about these cars all the time. I'd read long ago about this oil pressure unit relocation, but gave it no thought because my pressure gauge worked fine. Lately I've noticed that my gauge hovers around 40 psi at idle, but climbs to 70 or a bit more under acceleration or revving. Both the needle gauge and DIC read 0 psi when the engine is stopped. I've never noticed my gauge doing this until lately. I recently changed plugs and wires, but that should have nothing to do with oil pressure readings (especially since the sending unit is under the intake manifold). Is this erratic gauge a sign that it's failing? If so, when I take the car in for a few other fixes next week, I'll have them look at this too. Thanks!
What isn't normal about this? Of course the oil pressure will be 0 when the engine is off.
I've read on this forum that when the sending unit fails, there will be an oil pressure reading even with the engine turned off (ignition at RUN, but without the engine running). I'm not to that point yet, but I'm curious if my erratic readings points to a failing sending unit.
Reason: added more info
Only way to confirm is to use a mecahnical gauge to verify oil pressure.
