Window regulator
Old Sep 28, 2007 | 06:12 PM
Weprint's Avatar
Weprint
Default Window regulator
2000 Vert.
The R/S window is in the up position and will not respond to either door switch nor does it go down when I press the button to lift the convertible hatch release. I am getting the following codes.
AO-LCDM B2282H, B2284H, U1064H, U1096H
A1-RDCM B2283H, B2285H, U1064H, U1096H
BO-RFA U1096H, U1064H, U1016H, C2100H, C2105H
Any help would be greatly appreciated.
Old Sep 30, 2007 | 10:14 PM
SilvaDragon's Avatar
SilvaDragon
All your codes are History, so that doesn't make it obvious.
But check this out and see if it helps:
http://forums.corvetteforum.com/show....php?t=1739514
