Intake Manifold Torque Sequence
Old Oct 3, 2007 | 10:42 AM
razorhead's Avatar
razorhead
Default Intake Manifold Torque Sequence
Hi all am replacing oil pressure sending unit on 2001 LS-1. Can someone please send me a link to the correct torque sequence and ftlbs
Thanks in advance and also for all the great threads and info
Steve
Old Oct 3, 2007 | 12:20 PM
vettenuts's Avatar
vettenuts
Per the manual, they are tightened in two passes. First pass, 44 in-lb, second pass 89 in-lb. Note that these are inch-pound.
Sequence is middle pass, middle driver, then one back pass, to one forward driver, one forward pass, one back driver. Someone may have the diagram or it is available on LS1howto.com if you look at the LS6 intake swap.
Old Oct 3, 2007 | 12:59 PM
Tex_Vette's Avatar
Tex_Vette
Just Passin' Thru
Here's the link that vettenuts mentioned. As they say, a picture is worth....
http://www.ls1howto.com/howto/geniii...//IMAGE017.jpg
HTH, Tex_Vette
Old Oct 3, 2007 | 01:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
start from the center and work your way out.
To Intake Manifold Torque Sequence
