Lifters...Ticking Away
Old Oct 3, 2007 | 08:15 PM
spdnman's Avatar
spdnman
Default Lifters...Ticking Away
I have ticking / noisey lifters. I can live with the noise, part of the trade off for a cam, but am concerned. What is the cause and the fix? How do you know it is a lifter in the first place? What can happen negatively due to a bad lifter? Thanks, any information is appreciated.
Old Oct 3, 2007 | 08:44 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I have some experience with my '99's lifters. First off, how many miles on them? You have some mods, so there is always a possibility is that something is up with that. Lifters can and will wear out eventually. I'll describe my own and you can take it from there. Almost 3 years ago now, I was getting tapping sounds on cold startup. It started out by only lasting a few seconds then would get quiet as the oil pressure came up. Then it slowly took longer and longer to go away. Eventually, it kept tapping till there was a rise on the analog water temp indicator and then a few weeks later, it suddenly got real bad and loud. Between all that, I took it to the dealer and paid them to diagnose what I was pretty sure of already. The result was "Lifters bleeding down when cold". I took the top down on the engine, replaced them all along with new rockers, pushrods and had the heads processed at an engine shop with new brass racing valve guides, normal springs and seals. Put it all back together, problem solved.
Old Oct 3, 2007 | 08:45 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
IMHO, you should not have lifter noise if the geometry is set up correctly. I run an extremely large cam in mine and have almost no lifter or rocker noise. You will get so many opposing opinions (and they are just that) on this topic however, having worked on several of the LS1's with different cam profiles and applications from FI to NA, in every case where they had noise before, soon went away after the correct push rods were used and the swipe patterns were perfect. Its all in the detail. Good luck!
Old Oct 3, 2007 | 10:58 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I couldn't disagree more. If you lsiten closely, your stock c5 made a similar but much more faint sound. Like the ticking of a sewing machine. When larger lifters and push rods are installed, the noise will increase.
If "correct" means smaller, yeah...the noise will soften.
I am yet to hear a C5 with with extensive mods done, not make that distinct sound. I guess the 200 to 300 cars (including 4 different builds on my car, by 3 different highly respected LS engine builders) I have heard run....were all done with incorrect push rods?
Old Oct 4, 2007 | 05:45 AM
vettenuts's Avatar
vettenuts
I think you need to differentiate between sounds. A distinctive "tick tick" due to improper pushrod preload is correctable and geometry plays a role as does pushrod length on these motors. Aluminum loves to transmit sound waves though, and an aggressive grind will have what I call a "well oiled valve train noise". Hard to describe the difference with a keyboard. I do agree with 6 Kids on one thing, most people do not take the time to verify the wipe pattern and lifter preload. They buy the recommended parts and bolt the motor back together again. Sometimes things work well, sometimes they don't. Not saying this is the situation here, but all too often when I ask what the wipe pattern looked like you get the internet equivalent of the deer in the headlights back as a response.
Old Oct 4, 2007 | 06:07 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Now I am very interested in this. I recently had AFR 205s and a 228/232 cam put in. I replaced all the common stuff and replaced the lifters with new COMP lifters. I have a very loud "sewing machine" noise. In fact much louder than my last car when running a very close cam. My push rods are chromoly 7.4 length. What other specs are need to determine if there is anything that can be done to quiet the valvetrain noise down some? Thanks
Cajun
Old Oct 4, 2007 | 07:48 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
You must be able to see me looking at my screen right now
Old Oct 4, 2007 | 09:12 AM
spdnman's Avatar
spdnman
Thanks. What problems can occur besides a noisey valvetrain?
Old Oct 4, 2007 | 10:01 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
A lifter can eventually fail... and then you have to pull the motor and re-build it because metal goes everywhere. However failure is rare.
These motors sound like sewing machines... even bone stock my LS6 did it, my dad's LS6 does it, and my mother's '99 does it... as does every other LSX I've heard.
Yes, if your pre-load is incorrect then you can/will have excessive rattling, however it never goes away... a large cam is opening and closing the valves faster and moving them longer. It's just noisier.
Old Oct 4, 2007 | 10:57 AM
MN81C3's Avatar
MN81C3
I don't know if I am hearing the same sounds - I recently bought a 2001 with only 4451 miles on it. the first morning after I brought it home and started it in the garage - I heard lifter noise - something I never heard from my 81 C3. I went to a trusted Mechainc who is member of our club - he listened - smiled and had me follow him into the garage where he stated another 2001. Same sounds - slightly differant in tone but the same sounds. I was told if it gets louder or changes - then worry.
Old Oct 4, 2007 | 11:24 AM
Cobra4B's Avatar
Cobra4B
^ You also have piston slap on a cold motor.... aluminum expands/contracts. So when the motor is cold the pistons are smaller so they can slap in the bore a bit until the motor is warm. This is normal and won't hurt anything.
Old Oct 4, 2007 | 11:35 AM
vettenuts's Avatar
vettenuts
In this case (2001) I would tend to agree, my Pontiac Grand Am 3.1 has had piston slap since new, sounds like a diesel when I start it. Getting ready to turn over 190K miles and it still runs like a raped ape and gets 30+ MPG.
The valve train noise will be an issue if you are actually getting open lash, i.e., the pushrod is physically separating from the lifter/rocker. You need to have a proper preload, especially with stock lifters, as the clip that holds the plunger in place won't take much abuse so you need to ensure the plunger stays depressed within the lifter (keeps preload). The injectors can also contribute to this noise as well, but they have a more "clicky" sound.
Old Oct 4, 2007 | 11:38 AM
Cobra4B's Avatar
Cobra4B
^ I'm having 42s put in now... I'm wondering if the car will be louder or quieter since the injectors aren't working as hard... but they're bigger.
Old Oct 4, 2007 | 12:38 PM
jirasvet's Avatar
jirasvet
The valve train noise will be an issue if you are actually getting open lash, i.e., the pushrod is physically separating from the lifter/rocker. You need to have a proper preload, especially with stock lifters, as the clip that holds the plunger in place won't take much abuse so you need to ensure the plunger stays depressed within the lifter (keeps preload). The injectors can also contribute to this noise as well, but they have a more "clicky" sound" .
Injector noise commonly over looked.
IMO when a valve train noise becomes a problem it should make a distinct TAP TAP noise.
The purpose of the hydraulic lifter with proper preload is to ensure 0 lash on the valve train.
Like stated aluminum transits more sounds.
To Lifters...Ticking Away
