No Reverse lights, but bulbs work?
Old Jan 23, 2009 | 10:56 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I had a mechanic replace with a new switch today while he had the car jacked in the air for an oil change. The switch didn't fix it because the reverse lights still aren't coming on. The lights do work with the alarm. What else can I look for? Maybe a faulty switch?
I just noticed a tip for jumping it with a paper clip. What does that mean? Also, I want to make sure that the switch is on the passenger side of the tranny for MN6. Thanks in advance!
Old Jan 23, 2009 | 11:06 PM
baddboyz03's Avatar
baddboyz03
theres a 3rd fuse panel under the pass. side of the dash, down by the foot well, contains a fuse that controlls reverse lights!
Old Jan 23, 2009 | 11:28 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I thought there were only 2 fuse panels. One next to the battery and the one under the passenger side of the dash. I will check the fuses tomorrow.
Old Jan 24, 2009 | 01:10 AM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I am assuming that the fuses are good since the lights illuminate when I use the keyfob to lock/unlock the doors. I will check the various fuses and micro relays in the morning. Anything else I should check for?
Old Jan 25, 2009 | 01:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you suspect the switch, just unplug the connector from the swirch on the tranny and use a wire to connect the two contacts in the harness plug together and the lights should come on. (KEY in ON position)
If they dont, get a meter and see if you have the 12 VDC signal on one of the wires at that connetor.
BC
Old Jan 25, 2009 | 07:58 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I deserve a bonehead award! It turned out to be fuse #21 that was blown. When I checked the fuses a couple of weeks ago, I was pulling the wrong fuse out. LOL. I am a bonehead. All is good now. Thanks guys!
