Head Gasket Question
Old Oct 15, 2007 | 03:19 PM
Cujo67's Avatar
Cujo67
Default Head Gasket Question
I just purchased a set of Fel-Pro head gaskets for my C-5. My question is the head gaskets have a sticky side and a non sticky side, which side goes towards the head? Also the gaskets are the same laid side by side, so if the sticky side goes towards the engine block the gasket appears to be right because on the top of the gasket it says front (passenger side). When I put the driver’s side gasket on with the sticky side towards the block as the other, the front marked on the gasket is facing to the rear. Is there a left and right head gasket?
Thanks,
Cujo
