ground issue
Old Oct 15, 2007 | 07:12 PM
bayarea's Avatar
bayarea
Default ground issue
im in the process of hooking stuff back up and right now i have one ground hooked up to the drivers side head, 2 on the side of the drivers side block, and 1 ground along with neg batt cable hooked up on pass side block.
isnt there supposed to be a ground or 2 on the pass side head? if so where is it at lol.
car is a 2000
Old Oct 15, 2007 | 07:17 PM
corvettedoug's Avatar
corvettedoug
You have the negative batter cable right above the starter on the passenger side block. Not sure if you got that one already.
Old Oct 15, 2007 | 07:31 PM
bayarea's Avatar
bayarea
ya i got that along with a small ground underneath it.
thing is that the block i have is an lq9 and there is no were to put the neg batt cable right above the starter so i had to stretch them over to the next hole and im afraid the header will melt them.
any advise on the pass side head ground? is there any or is it just the wire harness holder?
Old Oct 16, 2007 | 10:12 AM
bayarea's Avatar
bayarea
from what i see on bill curlys sticky there is no ground on pass side head correct?
To ground issue
