ECU Problems?
Old Oct 15, 2007 | 10:46 PM
sickvett's Avatar
sickvett
Default ECU Problems?
When I'm driving around sometimes the windshield wipers start going on their own. Sometimes it says service abs and service traction control, then it turns off. It's really strange, everything just goes on randomly, then turns off.. lol
Old Oct 17, 2007 | 07:30 PM
duverneyt's Avatar
duverneyt
Cruising
Default Wiper pain
I have a 98 C5 and I think my wipers are going spastick? I'm driving along and they act like they want to start but stop and go back to the rest position. It's a constent problem now. I'm not getting any messages on the dash. Sure is distracting.
Old Oct 17, 2007 | 08:37 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The item that needs attention is probably the BCM located in the passenger footwell. Check for damp carpet there or evidence of water on the BCM. Also check all the grounds for clean and decent connections and while you are at it, check the battery connections. Bad grounds, lower battery voltage and water on the BCM will cause all sorts of issues. Also, pull the codes and see what may have been reported in there.
Old Oct 20, 2007 | 10:56 PM
sickvett's Avatar
sickvett
OK well I have all the error codes. I know I need an oil change, my right rear tire pressure sensor is bad, and my ac needs recharging.. I have no clue about the rest, here it is:
10-PCM: P0153 H, P0155 H, P1134 H, P1154 H
60IPC: B0521 H, U1016 H, U1176 H, U1160 H
99HVAC: B0367 H
A0-LDCM: B2264 H, U1064 H
28-TCS: C1225 H
A1-RDCM: B2263 H, U1064 H
B0-RFA: C2100 H, C2110 H C
Any Help Please? lol
Old Oct 20, 2007 | 11:12 PM
dgrant3830's Avatar
dgrant3830
DTC P0153 HO2S Slow Response Bank 2 Sensor 1
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
DTC P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
DTC P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
DTC B0521 Tachometer Signal Circuit Malfunction
DTC U1016 Loss of Communications with PCM
DTC U1176 Loss of Communications with RFA
DTC U1160 Loss of Communications with LDCM
DTC B0367 Right Actuator Feedback Open
DTC B2264 Vertical Position Sensor Circuit
DTC U1064 Lost Communications with BCM
DTC C1225 LF Excessive Wheel Speed Variation
DTC B2263 Horizontal Position Sensor Circuit
DTC C2100 Left Front TPM Sensor Malfunction
DTC C2110 Right Rear TPM Sensor Malfunction
Old Oct 20, 2007 | 11:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your wiper motor is submerged in water. The drains for the well are clogged.
Clean your udders!!!!!!!!!!!!!!!!!!!!
BC
dgrant3830's Avatar
dgrant3830
I think I would clear the codes, then see what happens when you start it up. Check for codes again. Then drive it, check for codes again after that.
I see Bill posted. Unfortunately I'm at work and whatever pics he put in there, I can't see from here. Listen to Bill! He's pretty sharp.
Old Oct 20, 2007 | 11:35 PM
BlackZ06's Avatar
BlackZ06
10-PCM:
P0153 H - SLo Response Bank 2 Sensor 1
P0155 H - Heater Perf Bank 2 Sensor 1
P1134 H - HO2S Transition Time Ratio Bank 1 Sensor 1
P1154 H - HO2S Transition Time Ratio Bank 2 Sensor 1
Is your exhaust system modified? If not you have problems with the Heated O2 sensors (Bank2 Sensor 1 and Bank 1 Sensor 1)
60IPC:
B0521 H - B0521 Tachometer Circ Malfunction
U1016 H, U1176 H, U1160 H - DELETE
I'd delete the B0521 if your tach is working OK - it is a history code
The Uxxxx codes are communication codes and should be deleted. Only usefull if the B0521 comes back
99HVAC:
B0367 H - Right Act Feedback Open
Indicates the HVAC system is having a problem controlling the warm/cool air flow to the right side of the car
A0-LDCM:
B2264 H - Vertical Pos Sensor Circ
Indicates a problem positioning the driver side external mirror. Since this is a History code I would delete it and see if it comes back.
U1064 H - DELETE
28-TCS
C1225 H = LF Excessive Wheel Speed Variation
Since this is a History code I would delete it and see if it returns. This code will disable your Active Handling and ABS systems if the EBCM considers it Current. If it comes back, post it and someone can help you diagnose it.
A1-RDCM:
B2263 H - Horizontal Pos Sensor Circ
Indicates a problem positioning the passenger side external mirror. Since this is a History code I would delete it and see if it comes back. U1064 H - DELETE
B0-RFA:
C2100 H - Left Front TPM Sensor Malfunction
C2110 H C - Right Rear TPM Sensor Malfunction
You say you know you have a problem with the sensors ...
Old Oct 20, 2007 | 11:39 PM
stevezfl's Avatar
stevezfl
I see your location is Seaside Heights.Are you close to the ocean with salt air? Might want to check all your ground connections. There are a lot of "loss of communication" codes in there.
Old Oct 21, 2007 | 12:57 AM
sickvett's Avatar
sickvett
Thank you very much. And yes I have a full exhaust, cam, intake, and 190' thermostat. I'm gonna try some things tomorrow, but how do I reset the codes? Once I reset them I'll post what came back.
Old Oct 21, 2007 | 09:19 AM
BlackZ06's Avatar
BlackZ06
Default How to reset DTC
Go here .... the RESET key in MANUAL mode will clear a code ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Oct 21, 2007 | 11:20 PM
sickvett's Avatar
sickvett
I did what it said and I can't reset the codes. When in manual mode, pressing reset does nothing. Am I doing it wrong?
Old Oct 21, 2007 | 11:45 PM
dgrant3830's Avatar
dgrant3830
In the manual mode, first select the first area that has codes, such as the pcm...then push and hold the reset for like 2 seconds. Then go to the next area and do the same.
Old Oct 24, 2007 | 12:53 AM
sickvett's Avatar
sickvett
Ok so I figured everything out and know whats wrong now. The newest code and the reason for my car running horribly is because it's misfiring. I need to change my spark plugs..
Old Oct 24, 2007 | 02:00 AM
BlackZ06's Avatar
BlackZ06
If you're gonna do plugs, I'd suggest new wires at the smae time.
Here's my recommendation ....
Plug wires from GM Performance Parts - order kit #12495519
Spark plugs - AC Delco 41-985 (Iridium) they come CORRECTLY pre-gapped at .040
Old Oct 24, 2007 | 12:50 PM
sickvett's Avatar
sickvett
I thought they were independent coils not wires?
Old Oct 24, 2007 | 01:03 PM
BlackZ06's Avatar
BlackZ06
Yes, each spark plug has its own coil. The coils are located on top of the valve covers just under the plastic covers on top of the engine that say CORVETTE on them.
The spark plugs are located much lower down and are basically located in between the exhaust headers.
The coils are connected to the spark plugs by individual wires. If you order ONE of the part number above for the plug wires you will get a box of 8 new wires.
The spark plug wires live in a tough environment. They get very hot because they are so close to the exhaust, and they have to deliver very high amperage electrical charges hundreds of times per second. Changing them when you change the plugs is what I would recommend.
Finally, the wires can sometimes be difficult to remove, and it is not uncommon to damage/break one or two wires trying to get them off the plugs.
On install, whether putting the old wires back on, or new ones ... be sure you hear a single "click" as you install them on the plugs, and if you are puttting on new wires, be sure you get a "double" click when installing on the coils. One click to the coils is not enough, push until you hear that second click.
To ECU Problems?
Old Oct 25, 2007 | 01:36 AM
sickvett's Avatar
sickvett
Oh and now apparently I need a new mass air flow sensor? wtf.. it's one thing after another.. haha
Old Oct 25, 2007 | 02:20 PM
timemender's Avatar
timemender
Most of the time the sensor needs to be cleaned and not replaced. Buy the special spray cleaner at any auto parts store.
Old Oct 26, 2007 | 01:36 AM
sickvett's Avatar
sickvett
Ok so now I have cleaned the mass air flow housing and let me say that the car runs a lot better... but it still misfires, so spark plugs next. I'm going with ACDelco Irodium plugs and ACDelco Wires. We'll see what happens when I change them. Thanks for everyones help.
