Need Help E-brake light
Old Oct 17, 2007 | 11:26 AM
jolitaly's Avatar
jolitaly
Default Need Help E-brake light
Under normal driving conditions my e-brake light comes on when I hit 2000 to 3500 rpm's and then cuts off when I shift but it doesn't come on all of the time. When I give it WOT it comes on almost all of the time around 2000 to shift. Also, I have noticed that every couple of days I hear a thud (like someone banging the side of their fist into the rear bumper) in the rear passenger side of the car. The only code I'm showing is the 1214 code which I know is caused by the EBCM which I'm fixing this weekend.
Would the EBCM cause something like this?
When the e-brake light comes on my car feels like something is tugging at it (like the e-brake is engaged) although my e-brake is loose. I need some help soon, I'm installing a Vararam intake, the new EBCM, and pulling the wheels off this weekend so it would be nice to pinpoint this problem as well. I'm an average at best mechanic but a competent person so if you guys think this is a problem that the $tealership should take care of just let me know. Thanks
Old Oct 17, 2007 | 11:43 AM
DeeGee's Avatar
DeeGee
The e brake microswitch is under the console attached to the e brake handle. I think its a tan/white wire
You could pull the console out and take a look at the switch to see if its loose in its mounting. Its a straight mechanical linkage. Pull handle - trip switch - applies voltage - brings on light on dash. Its separate to the actual operation of the e brake mechanicals. Its just an indicator
It could be moving and sending a false voltage under WOT?
Others may chime in
Old Oct 17, 2007 | 11:48 AM
BlackZ06's Avatar
BlackZ06
When you talk about the e-brake light, I believe you are referring to the BRAKE (red) warning light. That light will illuminate whenever the vehicle senses a problem with the hydraulic brake system. For instance, your brake fluid in the reservoir may be low enough that under acceleration the car is sensing a low brake fluid condition.
If the ONLY code you're showing is the C1214 ... I'd check the brake fluid reservoir.
Old Oct 17, 2007 | 11:49 AM
DeeGee's Avatar
DeeGee
You're a smart guy Stephen . That really is the most obvious problem seeing as its a dual role warning light
Old Oct 17, 2007 | 11:54 AM
DeeGee's Avatar
DeeGee
Just a thought, why the thump at the rear?
Any connection or just coincidence?
Old Oct 17, 2007 | 12:27 PM
BlackZ06's Avatar
BlackZ06
My GUESS is it is unrelated to the brake system issues. The only brake components in the passenger rear on a Z06 is the rear brake caliper/rotor combination. If the thump was consistent with brake application then I'd look at the brakes (loose caliper mount pins for example) but if it is "every couple of days" doesn't sound like brakes.
jolitaly - is there some other action you are taking with the car when you hear the thump ... such as performing a high speed left turn, or going overr a bump, or does it randomly occur while driving straight on a flat road ???? I'd look for loose/worn suspension components. Check the sway bar mounts, etc.
DeeGee - it's not that I'm smart .... just had enough "problems" with cars to have "been there, done that" ....
Helps to have had, over the years, a "bug-eye" Sprite, a couple of Jags, a Jensen-Healey, a Fiat X1/9 and a 124 coupe ....you definately learn to fix problems with cars like that ....
Old Oct 17, 2007 | 12:44 PM
jolitaly's Avatar
jolitaly
It occurs when I drive straight. I was thinking that it might of involved the e-brake locking up and then braking loose but I don't even know if that's possible.
I will check the brake fluid first and if that doesn't fix the problem then I will pull the console and check the connection. Any others ideas appreciated, I will keep you posted. Thanks
Old Oct 17, 2007 | 12:52 PM
LoneStarFRC's Avatar
LoneStarFRC
Bigfoot?
Old Oct 17, 2007 | 12:56 PM
LoneStarFRC
You might have to do a close inspection of all the rear parking brake hardware in the rear as well. Sure wouldn't hurt. I'm like the others. I'm not sure if the sound you're hearing is PB related or coincidental.
To Need Help E-brake light
