'98 headlights staying on?
Old Oct 18, 2007 | 10:53 AM
TimC's Avatar
TimC
CI 3-4-6-8-9 Veteran
Default '98 headlights staying on?
Hey guys,
Drove in to work this morning and the headlights won't go off. The headlight switch works fine when turned to the parking light position, but they stay on when in the off position. I've disconnected them, but the warning chime still thinks they are on. I pulled the 2 small fuses that control the headlight motor and they seem to be okay. If I manually close the lamps, they'll pop back up when I turned the headlight switch so I'm pretty sure it's not the motor.
Any other ideas what I should be looking for? Or is it a bad headlight switch inside the car?
Old Oct 18, 2007 | 11:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like you may have either a bad ground OR the head light control module is bad.
Check and clean grounds g-101 and g-102.
BC
