Run-flats Rock!
Old Oct 18, 2007 | 01:06 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Default Run-flats Rock!
I had my first flat tire with my vert two days ago. My DIC told me the left rear time was low, so I aired it up. At that time, I saw a piece of metal sticking out. I thought it was superficial, so I pulled it out; then, I heard the loud hissing! Then, I said to myself, no problem; I have run-flats! So, I drove off, and got it repaired later that day.
I was considering whether to replace these tires with more run-flats when they wear out. Now, I am definitely going to! That was so cool, driving with a flat tire...
Old Oct 18, 2007 | 01:18 PM
timemender's Avatar
timemender
As far as a flat tire is concerned, they do indeed "rock".
Old Oct 18, 2007 | 01:41 PM
02gt350's Avatar
02gt350
even so, if you drive to far, they will still need to be replaced
Old Oct 18, 2007 | 01:43 PM
clif's Avatar
clif
Very true, but I only had to drive about 8 miles to a Goodyear store.
Old Oct 18, 2007 | 01:59 PM
silvershadow1999's Avatar
silvershadow1999
Default runflats
just had front and back Goodyear runflats installed . expensive!? you bet. I'm getting a bit better gas mileage and the ride is much better. I went round and round "get it", should I buy runflats or not to buy runflats. I'm glad I stuck with the runflats.
Old Oct 18, 2007 | 03:00 PM
kilrb's Avatar
kilrb
If you don't mind lots of road noise and poor performance, run-flats are great. I figure I'll up my insurance plan to cover a tow when I buy new tires, and I'll go with non-run-flats. I'm not going to worry about the miniscule chance that I'll get a flat and have to wait an hour for a tow truck and buy the tire that meets my performance (and decibel) needs 99.9% of the time.
Old Oct 18, 2007 | 03:03 PM
clif's Avatar
clif
You want a tow-truck to handle your vette??? Better rethink that!
Old Oct 18, 2007 | 03:08 PM
jovette's Avatar
jovette
I agree. Would not want any hayseed to put a hook on my vette. Also would be concerned about having the vette put on a flatbed......don't know that they'd get that done, especially on a vette with a flat tire, without damaging the underside of the front and possibly rear of the car.
Old Oct 18, 2007 | 03:59 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
All good points but i will stick with my Michelin PS2's and never go back to run-flats.
Old Oct 18, 2007 | 04:07 PM
blu00rdstr's Avatar
blu00rdstr
I left my vette in the hands of a tow truck driver once who had to call a flatbed, and I caught a ride home. When he dropped the car off at home I tipped him $40 because it was miserable weather. A few weeks later I crawled underneath, and found four deep jack pad imprints in the fiberglass.
Too much time had passed to do anything about it.
Old Oct 18, 2007 | 04:21 PM
nickolbag's Avatar
nickolbag
The wheels will still roll even if you have a flat. If the wheels roll the car will move and if you put a flat bed in front of it then it will move on to the flatbed. Seriously, theres nothing complicated about driving a Vette onto a flatbed, flat or no flat. Worked for me when I had 2 flats at once. No damage.
Old Oct 18, 2007 | 05:12 PM
kilrb's Avatar
kilrb
I think the biggest thing is to make sure it's a flatbed, and watch while they load/unload it.
Old Oct 18, 2007 | 05:32 PM
nickolbag's Avatar
nickolbag
Exactly.
Old Oct 18, 2007 | 06:53 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Make that another!!!
Old Oct 18, 2007 | 06:59 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
amen
Old Oct 18, 2007 | 11:06 PM
01vetter's Avatar
01vetter
Question for you guys that have had your vette flatbedded. I looked at several that had their bed fully extended and it looked like it had to steep an angle for the front end, particularly if you had a front flat. Also, I would be concerned about them using the typical chains for pulling the car up. I don't see many of them using nylon webbing. Also, where did they hook your car to pull it up the ramp?? I would be very interested in this.
Old Oct 18, 2007 | 11:24 PM
schmaltzr's Avatar
schmaltzr
Default Ive had mine towed 3 times
Every time I've had to have a tow, I always insist on a flat bed and have to wait up to 3 hours for it to arrive. I know they didn't scrape the bumper at any time, they had ramps to extend the bed and reduce the angle. I think they attached to somewhere on the frame under the engine using nylon straps (not chains). I wouldn't let them tow it from the front end components because I was afraid they would torque it out of alignment. They were very gentle I suppose because I was there to supervise. I stay with the car no matter what.
To Run-flats Rock!
Old Oct 18, 2007 | 11:50 PM
dyeggy's Avatar
dyeggy
St. Jude Donor '10-'11-'12, '14-'17,'21, '25
I changed my run flats at 20k miles to the GSD3 tire. I had 2 nails in the run flats and had them changed at my convienence.
I believe that the car handles slightly better now with the new tires. I have had 2 flats in the last 10k miles(GSD3 tire...both times tire had to be replaced due to nail/spike through the side wall). I have the ContiComfort kit from Tire rack and it has saved me both times with the non-runflats.
All that being said, I will probably get run flats when these tires need to be replaced. Heard great things(here on the forum) about the Michelins. Might have to try those next time.
Old Oct 19, 2007 | 02:21 AM
DefenderC5's Avatar
DefenderC5
Runflats are pretty good at running flat... but that's about it. Oh, and draining your wallet
Sensor safe tire repair kit and a cell phone for me, I'd rather have the quieter ride and better handling.
Old Oct 19, 2007 | 02:37 AM
LoneStarFRC's Avatar
LoneStarFRC
I would recommend that anything stuck in the tire (especially if you are getting a low pressure warning) NOT be removed until you get to a repair facility. This applies to either type tire.
The OP said he aired the tire, so it would seem that the tire was not completely flat, until the object was pulled out. Point is: don't guess or assume the object is some minor thing because if you guess wrong, it will guarantee the tire will become completely flat. Usually in short order.
Leakage situations are by far the most common type of tire problems from foreign objects. There have been several times in the past where I was getting a low pressure indication and I just aired the tire up so I could get to a shop. Then, and only then, should the object be removed.
