Help with a code please
Old Oct 18, 2007 | 05:10 PM
boydmc85's Avatar
boydmc85
Default Help with a code please
97 Vette coupe
Recently experienced a small elevation in water temperature that had not recently occurred. Occasionally the A/C will cool very well and then it will not, regardless of outside temp.
Checked the DIC codes today and had the following:
HVAC B0361 H C
Code list says
HVAC - Heater, Ventilation, Air Conditioning
B0361 Left Actuator Feedback Short to GND
Can someone translate this into English for me please.
Thank you.
Old Oct 18, 2007 | 05:31 PM
jirasvet's Avatar
jirasvet
It means the actuator that controls the door position for the driver side
climate control is out of range or not working. The actuator adjusts the door on the vent to adjust for desired temp There is a topic on the forum about re-indexing the actuator if it is not broke.
Old Oct 19, 2007 | 10:35 AM
boydmc85's Avatar
boydmc85
Thanks for your reply. Looks like I'll try to reset the actuator and if not, will need to replace it.
To Help with a code please
