Throttle Body size diffrence ?
Old Oct 18, 2007 | 09:15 PM
fsuforever's Avatar
fsuforever
Default Throttle Body size diffrence ?
anybody know How Much Bigger is the Ls6 vs the Ls2 vs Ls1 ?btw i think the ls1 is 75 & the ls6 is 80 ,not sure about the Ls2 it may be 90 ,i dont know
Old Oct 18, 2007 | 09:18 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
great question...always wondered but have never asked...
Old Oct 18, 2007 | 09:32 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
LS1 and LS6 use identical 75mm 3 bolt throttle bodies.
LS2 uses a 4 bolt 90mm, and you need a different or modified manifold in order to use it.
Old Oct 18, 2007 | 09:36 PM
fsuforever's Avatar
fsuforever
From what my book says the early LS1 Throttlebodies are 75mm & the Ls6 are 80mm dont know what the Ls2 is , the Lq4 is also 80mm but it is cable actuated whereareas the Ls6 is Etc,The LQ9 ?
Old Oct 18, 2007 | 09:40 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
LS1/LS6, no difference whatsoever in throttle bodies, sorry.
You might be thinking of MAF sensor sizes?
Old Oct 18, 2007 | 09:45 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I believe he is reading from the "How to build a Chevy LS1 and LS6/ v-8motor" book. If so, the author is referring to the TB not the MAF, but to the best of my knowledge his sizes in the book are incorrect. I believe the TB for LS1 is 78mm, and the same for the LS6. Not positive though.
Old Oct 18, 2007 | 09:52 PM
khadiyev's Avatar
khadiyev
so what is the difference in the MAF size/flow? Ls1, Ls6, Ls2?
i thought that Throttle body on a Ls1 is 78mm
Old Oct 18, 2007 | 10:09 PM
Johnny Hardcore
I make 428rwhp and use the stock TB. My buddy Mark, makes 736rwhp, stock TB. The stock unit will work just fine. I personally, would spend my money elswhere.
Old Oct 18, 2007 | 10:17 PM
Johnny Hardcore
I don't believe a size difference is the big differentiator here. The LS6 MAF has the screen removed, allowing an increase in airflow.
Old Oct 18, 2007 | 10:21 PM
fsuforever's Avatar
fsuforever
Yep: ,How did u know ?wonder why they put that info in here if its incorrect I may need to write the editor of the book ,he may allready know http://www.performancethrottlebodies.com/Home_Page.php
Old Oct 18, 2007 | 10:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Early (97-00) LS1 3 pin MAF's were 75mm.
ALL 01-04 C5's (LS1/LS6) used 85mm 5 pin MAF sensors, which also incorporated the IAT sensor in it..
The screen was removed only on the on 02/later LS6s.
Old Oct 19, 2007 | 01:01 AM
speedsk899's Avatar
speedsk899
The LS2 is 90mm, it is a direct bolt on with a Fast 90 intake on a LS1, with wiring of course
Old Oct 19, 2007 | 01:44 AM
blu00rdstr's Avatar
blu00rdstr
Here's my old LS1 throttle body and new LS2 throttle body, and the L76 manifold. LS1 throttle body is 75mm, and the LS2 is 90mm.
Old Oct 19, 2007 | 10:01 AM
fsuforever's Avatar
fsuforever
Nice Pics the Ls2 TB is way Bigger than the Ls1 throttle Body
Old Apr 21, 2012 | 09:18 PM
v84life's Avatar
v84life
Yea makes me wish I went with Fast 90 and ls2 throttle body conversion, but hard to come up with the money all at once.
Old Apr 21, 2012 | 10:49 PM
LoneStarFRC's Avatar
LoneStarFRC
Be careful what you wish for. If you don't have significant mods in other areas of your engine, i.e. heads/cam/exhaust, etc your airflow velocity could take a big dump by bolting on a big TB and you could have a dog not only in perfomance overall, but crappy throttle response as well.
Old Apr 21, 2012 | 11:18 PM
v84life's Avatar
v84life
Yea I have full bolt ons full exhaust G5x2 cam on the stock 241 heads Im working on installing a ported fast 78 now and have a bored out/ported stock throttle body opened up to 78mm. should make good numbers going from a non ported ls6
To Throttle Body size diffrence ?
