Halltech Stinger - how to clean?
Old Oct 19, 2007 | 07:34 PM
MyOwn69's Avatar
MyOwn69
Default Halltech Stinger - how to clean?
We've moved and I've lost my directions!
It's due for a cleaning - what do I do?
Thanks!
Old Oct 19, 2007 | 07:39 PM
hotwheels57's Avatar
hotwheels57
You can use a K&N filter cleaning kit. If you don't have enough cleaning solution, diluted SIMPLE GREEN is fine for cleaning. Put some in a spray bottle and spray generously over the outside of the filter. Then run a steady stream of water over the pleats. I like to direct the water from the inside to help flow the dirt to the outside.
Air dry over night after cleaning. Sparingly apply oil to the dry pleats and allow it to wick through the filter. Again, allow this to happen over night if possible so you can see any places that might need a little touch up.
Don't over oil or you may contaminate the MAF wires.
Old Oct 19, 2007 | 08:34 PM
MyOwn69's Avatar
MyOwn69
I thought it was something like that - thanks!
Old Oct 19, 2007 | 11:48 PM
Dave68's Avatar
Dave68
Check in here for my cleaning procedure (and a few more DIYs):
http://www.conceptualpolymer.com/corvette_c5_corner.htm
To Halltech Stinger - how to clean?
