Push Button lights out
Old Oct 20, 2007 | 09:11 PM
Tigger's Avatar
Tigger
Default Push Button lights out
The light behind my FUEL and GAUGES buttons has gone out.
Can the bulb be replaced without pulling the instrument cluster?
The service manual is no help!
Old Oct 20, 2007 | 11:20 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The switch assembly is screwed in from behind the cluster. Supposedly you can get the cluster out without removing the dash pad itself by lowering the steering column. I have removed the dash pad on my '99 to replace the HUD. Time to remove and replace, ready to drive, 2.5 hours.
Old Oct 20, 2007 | 11:37 PM
Tigger's Avatar
Tigger
I have removed the cluster in the past ( gauge bezels ). I was
wondering if the switch cover could be removed from the front
without screwing something up, and the bulb changed without
pulling the cluster.
Most likely wishfull thinking.
Old Oct 21, 2007 | 12:28 AM
dgrant3830's Avatar
dgrant3830
The switch unit bulbs are put in from the backside of it.
To Push Button lights out
