Raising Front End
I have installed a front spoiler and it scraps on EVERYTHING, I'm lowered on stock bolts and would like to raise it by 1/2", I'm hoping it's not a trial and error type of thing, lift car/turn bolt/lower car and repeat
Lowering Notes
Measurement before lowering - ground to fenderwell:
Rear 28 3/4"
Front 27 1/4"
Rear: 11 threads showing on the bolt when viewed from the top of the spring
Front: 11 turns out from all the way down (turn counter-clockwise to lower car)
After lowering around Mid-February, 2006:
Both front and back dropped about 7/8"
Rear: left 3 threads showing on bolt on top of spring
Front: 11 revolutions counter-clockwise to bottom, then 1 revolution clockwise to be just off bottom
After raising back up on 2/28/06:
Rear: 11 threads showing on the bolt on top of spring
Front: Only able to turn clockwise 10 1/4 turns
Rear: 28 7/8"
Front: 27 7/8"
Rake should be 1/4 - 3/8" difference between front and back, measured at frame rails just behind front wheels and just in front of rear wheels.
3/2 Left front was 28
Right front was 27 3/4
Lowered left front 5 turns Now 5 1/4 clockwise turns from lowest position
Lowered right front 3 turns Now 7 1/4 clockwise turns from lowest position
3/12 Left front was 27 3/16
Right front was 27 1/8
Raised left front 1/2 turn Now 5 3/4 clockwise turns from lowest position
Raised right front 1 turn Now 8 1/4 clockwise turns from lowest position
Left front now 27 5/16
Right front now 27 1/4
3/15 At screw near jacking point on frame using small 3 foot tape measure:
Left front: 5 3/8 Right front: 5 2/8
Left rear: 5 4/8 Right rear: 5 5/8
Did not touch left front Still 5 3/4 clockwise turns from lowest position
Raised right front 1/2 turn Now 8 3/4 clockwise turns from lowest position
3/17 At screw near jacking point on frame using small 3 foot tape measure:
Left front: 5 3/8 Right front: 5 3/8
Did not touch left rear Still 11 threads showing
Lowered right rear 1/2 turn Should now be 10 1/2 threads showing
3/23 At screw near jacking point on frame using small 3 foot tape measure:
Left front: 5 3/8 Right front: 5 1/4
Left rear: 5 1/2 Right rear: 5 5/8
Raised left rear 1/2 turn Should now have 11 1/2 threads showing
Did not touch right rear Should still have 10 1/2 threads showing
Did not touch left front Should still be 5 3/4 clockwise turns from lowest position
Raised right front 1/2 turn Now 9 1/4 turns from lowest position
3/24 At screw near jacking point on frame using small 3 foot tape measure:
Left front: 5 7/16 Right front: 5 7/16
Left rear: 5 5/8 Right rear: 5 6/8
Did not touch left rear Should still have 11 1/2 threads showing
Lowered right rear 1/2 turn Should now have 10 threads showing
3/29 At screw near jacking point on frame using small 3 foot tape measure, with full tank:
Left rear: 5 5/8 Right rear: 5 5/8
) in a few weeks, so I may wait until next spring to do this. I'm sure your info will be a great help when I do get around to doing it though.Thanks again,
Ray
