60lb injectors ?
Old Oct 26, 2007 | 08:25 PM
fsuforever's Avatar
fsuforever
Default 60lb injectors ?
I have been told by a Tuner Here in MObile,al that the 60lb injectors are hard to tune ,This is what he says , First of all, they have a 6% variance +/- from the factory. Yes, some flow around 64# and others flow around 56#. And, that could be from cylinder to cylinder. The only 60s that I trust to never have any quirks are the flow matched set. Do you have a flow matched set? Did you even know that about those injectors? It's one of the worst variance of any aftermarket injector. You may know me as a friend, but I'm also a professional tuner, therefore I'm going to inform my customers about the setup.OK now
I am trying to get a tune ,& i Bought the Paxton kit from Chris @ Ecs ,Chris tells me these injectors are one of the easiest to tune ,I dont know what to believe
Old Oct 26, 2007 | 09:04 PM
78Vette-SA's Avatar
78Vette-SA
Take Chris' word for it.
I've tuned a number of cars with 60's and never had any problems.
Old Oct 26, 2007 | 11:33 PM
FRCTony's Avatar
FRCTony
I would find a different tuner before you end up buying a new engine.
Old Oct 27, 2007 | 11:56 AM
RED99's Avatar
RED99
When in doubt, check it out. It's only about $120 to get the cleaned and flowed. IF they are new, it should be a lot less just to get them flow tested.
Old Oct 27, 2007 | 08:52 PM
fsuforever's Avatar
fsuforever
Where do u recommend getting the injectors flowed & Tested?Yes they are New,never has had any Fuel ran thru them
Old Oct 27, 2007 | 11:01 PM
78Vette-SA's Avatar
78Vette-SA
One option ($17 each).
http://www.witchhunter.com
Old Oct 28, 2007 | 01:42 AM
jmoody66's Avatar
jmoody66
Default ez
Ive got em and the tuner had no prob whatsoever.
Old Oct 28, 2007 | 03:05 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
You dont know whos advice to take??? Chris at ECS, or some guy who tunes cars in Alabama???
Old Oct 28, 2007 | 08:48 PM
fsuforever's Avatar
fsuforever
Nope ,To be Honest i Have several people telliing me 2 or 3 Diffirent things as far as tuning issues with the 60s ,The tuner i have down here is having problems with Fords & The 60lb injectors ,he says theres a Vairance in the injectors hes been tuning & wanted to warn me about the 60 s,I told him it was a little late for the warning ,ive had the kit for 3 months now ,& I am Just now being able to put it on my car ,& i Think the Injectors i Have from Chris came from him allready flowmatched 60lb motrons
Old Oct 29, 2007 | 11:40 AM
CrazyChris's Avatar
CrazyChris
60lbers are cake to tune.
To 60lb injectors ?
