C5 -Upper Control Arms Frame Attachment Insert broke
Old Oct 27, 2007 | 07:34 PM
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
Default C5 -Upper Control Arms Frame Attachment Insert broke
How do I fix the threaded insert in the frame? If anyone has had to make such a repair I need advice
I had the upper contol arm unbolted from the frame today as I was in the process of changeing the front spring. When I went to re-attach the bolts were very stiff. I checked over and over for cross threads but could not identify it so I just strong armed it. Big mistake!!!
One of the threaded inserts in the frame rail broke free and now I can't tighten or get the bollt out. I'm sure I will have to cut the head off.
How do I fix the tread insert is my big concern. If anyone has had to make such a repair I need advice.
Old Oct 27, 2007 | 07:45 PM
hotwheels57's Avatar
hotwheels57
You can buy aluminum or steel thread inserts in SAE and Metric along with a hand tool at many hardware stores. They're intended for thin gauge metal/plastic applications, however. They're in no way intended for the stress that a control arm would probably be put under.
You might have to resort to GM, or a body shop/frame shop for advice on your situation. There are heavy duty versions available for commercial use.
Do an internet search using keyword "heavy duty threaded insert tool" and you'll find a number of sources for the tools and inserts. The cost for the tool and inserts for just one repair might be expensive.
Old Oct 27, 2007 | 08:31 PM
FOLDNTOP's Avatar
FOLDNTOP
I emailed ALCOA. I don't have any choice about cost car is apart in my garage and can't go to dealer. Hopefully someone has direct experience that will save me the trial and error process.
Old Oct 27, 2007 | 08:53 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I am not certain without seeing it,but I used an insert tool for some of the smaller sizes(as in the skid bar attachment points).
My gut tells me you need a lot of strength in that area,so I am not really sure if they are inserts or not.If they are,it should not be that big of deal to replace,but it may be expensive for a one or two time deal, as has already been stated.
That's all the info I can give at this time......hope for inserts there
Old Oct 27, 2007 | 10:58 PM
FOLDNTOP's Avatar
FOLDNTOP
Originally Posted by FOLDNTOP
The problem insert broke free and can't remove bolt.
Rear holes drivers side bolts removed
Close up of inserts on passenger side
I need to replace the insert on the drivers side.
Shocks have been removed. I am installing 2004 Z06 Springs shocks and sway bars and this is one of those PIA delays.
Anyone had this problem???
Appreciate any and all suggestions.
Old Oct 28, 2007 | 02:28 AM
Bill Dearborn's Avatar
Bill Dearborn
Get the rest of the work done and install 3 of the bolts and get the car to a dealers shop. You will need to do a re-alignment anyways so let them fix the insert while doing the alignment. If it isn't too far away you may be able to drive the car there as long as you keep speeds and cornering forces to a minimum. You could also have the car flatbedded and maybe your insurance would cover the flatbed/towing charge.
Bill
Old Oct 28, 2007 | 04:17 AM
eldudereno's Avatar
eldudereno
Give some of your local sheet metal shops a call. Tell them the bolt size and the thickness of the material where the insert is attached. They might well have a hand tool available that'll pull in a new insert for you.
Old Oct 28, 2007 | 07:59 AM
BlackZ06's Avatar
BlackZ06
The bracket that the "inserts" are in appears to be part #10421764, I can't see a seperate part number for the "inserts". The bracket appears to be welded to the frame, so a body shop, worst case, should be able to replace the bracket. The upper control arm mounting bolts are only supposed to be torqued to 48 lb/ft.
The bolt is listed in the parts manual for a 1999 as part #11515768 and if this description helps in locating aan "insert" here's what the parts manual says ...
BOLT, HFH, M10x1.5x40, 30 THD, 22.3 OD, 10.9 MAT, 7114M FIN. MACH, RED BDY (Frt Upr Cont Arm)
I'd do as others recommend and take it to an auto shop or body shop and get their opinion .... if the car is undriveable, the pictures you posted above should be fine for a Corvette specialist to understand what the problem is, just take the pictures in.
Good luck,
Old Oct 28, 2007 | 08:17 PM
hightest's Avatar
hightest
Just weld a couple of tacks around the outside perimeter of the insert, and then you can get the bolt out. After the bolt is out grind off your tacks and you can replace the insert. You will probaply have to build up the hole with weld, and re-drill to the proper size before you install the new insert; as it sounds like the hole has been enlarged from the insert turning inside of it.
Old Oct 28, 2007 | 08:37 PM
flynbya2's Avatar
flynbya2
The holes I have seen ,so far,that GM uses for these inserts has a hexagon back side.So,if that is the case here,you would probably need to weld and then file it back to the correct shape to grab?
That's my initial thoughts on the matter
Old Nov 6, 2007 | 06:02 AM
FOLDNTOP's Avatar
FOLDNTOP
Took the car to Powell Motorsports in Port Perry ON today and had Devon repair the insert. We tried TIG welding the old one but that didn't work. We then welded a 10.9 nut to a steel bar and installed it in the frame. TIG welded everything and it works fine. Once the welds were ground down and painted you would never know there was a repair. I now have one that is stronger than all the rest. I am pleased as can be. Can't thank Devon enough they do great work at the race shop!...
Old Aug 23, 2022 | 02:27 PM
bakeman_94's Avatar
bakeman_94
I know this is a super old thread, but do you remember how they accessed the inside of the frame? I have the same problem and need to repair it
Old Aug 23, 2022 | 02:37 PM
Supercharged111's Avatar
Supercharged111
It just looks like a giant rivnut. I wonder if you couldn't carefully drill/remove the old one and just install a new one?
Old Jun 25, 2023 | 10:56 PM
sirtoast's Avatar
sirtoast
2nd Gear
did you ever get this fixed? I am in the same boat, if you did what did you pay and what had to happen?
Old Jun 25, 2023 | 10:57 PM
sirtoast's Avatar
sirtoast
2nd Gear
how much did you pay and how did they get inside the frame? I suffer this same problem right now.
To C5 -Upper Control Arms Frame Attachment Insert broke
