Need help with LapTrax install
Old Oct 31, 2007 | 05:15 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
There are seven wires in the DIC switch:
gray-ground
orange-fuel
brown-gauges
white-trip
green-options
red-e/m
blue- reset (It is dark blue)
I actually pulled the connector loose with out removing the ignition switch. But there was no way I was going to reconnect it with the ignition switch in place.
To remove the ignition switch:
Insert key and turn to ON position
Using a small flat blade screwdriver depress and hold the ignition lock cylinder retaining tab. It is located on the RH (passenger) lower side of the ignition switch. Small rectangular opening.
Pull out the ignition lock cylinder
Remove the two small bolts
Drop the switch out of the way.
Old Oct 31, 2007 | 05:18 PM
craig04c5's Avatar
craig04c5
Thanks Doug. Good info for me to have before I start. Thanks to all who have provided input.
Old Oct 31, 2007 | 05:52 PM
Former Vendor
Sorry Craig, to do what I did you have to remove the center console. I had it out to install a gauge.
Old Oct 31, 2007 | 06:03 PM
craig04c5's Avatar
craig04c5
Thanks Doug. I've had it out before to put the C6 shifter in so it's no big deal for me to remove it.
Old Jun 26, 2014 | 02:17 PM
Dirty 30's Avatar
Dirty 30
I know that this is an old thread but I am looking for the wiring diagram to install a laptrax module. It is the non-deluxe version (unfortunately).
Old Jun 26, 2014 | 03:41 PM
craig04c5's Avatar
craig04c5
I'll see what I can dig up for you. BTW I have the deluxe version and when we took the dash apart we could not figure out which brown wire to connect to the DIC. I think I know now but really I kind of like the display saying Competition Mode so I know it is ready.
Old Jun 26, 2014 | 03:49 PM
Dirty 30's Avatar
Dirty 30
I figured the yellow and black wire out. Now I just need to know where the brown wire goes.
Thank you!
Old Jun 26, 2014 | 04:37 PM
craig04c5's Avatar
craig04c5
Thank you!
Here you go. Hope it helps.
page 2
Old Jun 26, 2014 | 05:20 PM
Dirty 30's Avatar
Dirty 30
Thanks a million!
Old Jun 26, 2014 | 08:56 PM
craig04c5's Avatar
craig04c5
Thanks a million!
