tire?
Old Oct 30, 2007 | 10:03 PM
gunslinger40's Avatar
gunslinger40
Default tire?
i am looking to purchase zo6 wheels and tires for my c5. do i have to run runflat tires? if not what will the display on the dash say? thanks
Old Oct 30, 2007 | 10:07 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
You put your old (or buy another set) tire pressure sensors in your new wheels.
jeff
Old Oct 30, 2007 | 11:56 PM
wamara's Avatar
wamara
Cruise-In II Veteran
The sensor does not know what kind of tires you have. All it is doing is measuring the air pressure inside a pressurized compartment (to wit, the inside of your tire). If you could inflate and seal a trash bag around your wheel, it would still measure the pressure.
Bottom line, switch the sensors to your new wheels (make sure you locate them the same way as they were originally (i.e., RF to RF, LR to LR) and use whatever tires you want.
Old Oct 31, 2007 | 12:35 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Michelin Pilots
I went with the non run flat Michelin Sports and I never told the Tire Pressure Sensors a darned thing! The only thing I told them was that Daddy Dan-Na was taking them out for a drive to Costco! They'll do fine and if you go with the non runflats, you will always know BEFORE you get a flat. Just pick up the following:
1.) Inexpensive Air Compressor with a cigarettte lighter plug-in.
(mine was $14.95)
2.) Tire Plug Kit
(mine was $8.00)
and you will be covered!
Old Oct 31, 2007 | 07:01 AM
gunslinger40
how do the sensors mount, what do i have to do to motorsport z06 wheels to make them work? thanks for reply's
Old Oct 31, 2007 | 11:38 PM
wamara's Avatar
wamara
Very simple - there is a nut that is threaded on the valve stem. Loosen it and you will free the sensor from the wheel rim. If your car is a 97-00 model, you may want to change the o-ring on the stem.
Old Nov 1, 2007 | 06:18 PM
gunslinger40
so the sensor is external from inside the tire? do they have to be reinstalled on the wheel before the tire is mounted? thanks
Old Nov 1, 2007 | 07:57 PM
TopFuelTim's Avatar
TopFuelTim
Sensor mounts from inside of wheel. Valve stem sticks outside. Yes, you do want to re-install sensor on wheel before tire is mounted. It's pretty easy.
Tim Glover
To tire?
