engine getting warm on a cool day
and then at a light it goes to 235
then when I get up to speed it cools back to 217 deg . I've remove the Radiator cover and ensure there no blockage or trash in it. could it be the thermostat ?
I've check the fluild level and its good . I can't figured it out .
Corvette Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Try turning on your Air Conditioner while stopped and see if your temperature goes down.
