Electrical Connection Cleaning & Sealing
Old Nov 4, 2007 | 09:16 PM
brian vette's Avatar
brian vette
Default Electrical Connection Cleaning & Sealing
Any ideas about the best way to clean the electrical connectors on the grounds/fans/active handling unit ect. ect. ect. and should any sealer be used to protect these connectors during reassembly?
Old Nov 4, 2007 | 10:03 PM
Last C5's Avatar
Last C5
I want to know this too. Come on you dot com kids, what's the secret stuff to use.
Old Nov 4, 2007 | 11:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Autozone and Advance sells some electrical contact sprays but this is what I have used with success:
It will not effect the electrical conductivity of the circuit and keeps the moisture out and corosion off.
BC
Old Nov 5, 2007 | 10:19 AM
ProDesign's Avatar
ProDesign
Deoxit & ProGold from Caig Labs www.caig.com (application info & testominals on website)
Can also be purchased at RadioShack.
http://www.radioshack.com/product/in...entPage=search
Old Nov 5, 2007 | 10:52 AM
Bluefire's Avatar
Bluefire
Use sandpaper on the terminal lugs and grounding surface around the bolt hole to remove all of the corrosion (white stuff). Then spray the lugs and the ground surface with any good electrical cleaner.
Old Nov 5, 2007 | 05:59 PM
chemcat's Avatar
chemcat
Default Cleaning and sealing electrical connectors
To CLEAN, I usually just do it manually by scraping the metal connectors with a sharp edge, like a single edge razor blade (you'll have to be creative to clean tiny female connectors, but it can be done; try SMALL drill bit scrape and do it manually).
To SEAL, I just use pure Petroleum Jelly. (Heck, just use axle grease if you want to). Wipe off outside when done.
Can't get much cheaper than this, and it works fine.
-doug
PS: while you're at it, take your battery out and clean it with baking soda and water, rinse off, let dry; scrape the terminals with a sharp blade, then coat with petroleum jelly (just the top is enough; maybe a little down along the sides from the top), that will END any future corrosion problems at the bat terminals. Great protection for winter too.
Old Nov 5, 2007 | 06:24 PM
LoneStarFRC's Avatar
LoneStarFRC
Cool! Thanx!
Old Nov 5, 2007 | 06:53 PM
brian vette
Default Electrical Handy Advice
Thanks Guys
To Electrical Connection Cleaning & Sealing
