Took my 99 FRC to the Track last night and Broke it !!! Wheel hop and then nothing.....The Diff case is still together drainded the fluid and it looks fine ....Not sure what it is...It seems like all the times i have heard of the Rear going out it explodes....Not sure what broke...Thoughts??
any chance that you broke it at Baytown and your cars is red?
If you only broke the shaft you are lucky, my guess is driver's output shaft. DTE has a very strong warning against wheel hop in their warranty information. It you are going to race the car, you need to address the wheel hop as well.
Yeah it was the first time down a track.....I removed the Diff and it only broke the Pass Side outPut shaft......I hope to have it going by next weekend
Wow, that's uncommon. So is the left output shaft already hardened? If you are going to drag race the car, you need to have hardened output shafts in the differential....period. I just watched a guy in a new C6 this weekend blow his rear end at the strip. If your left output shaft is not hardened, it will happen again. It's only a matter of time.
I am not sure if it is or not...I took the Diff out and dropped it off at the shop and he said he was going to give me a call once he got it all apart...I hope it is so I only have to by one
