? on removing steering rack
The real important part is to make sure you don't spin the steering wheel while things are disconnected. Even a string or bungee cord around the steering wheel to the shifter or brake handle will suffice.
The only goal is to make sure you reconnect it in the same position as you unbolted it, and not 180* (or worse) off.
Cant mess up the alignment or you will be SORRY!
Just keep the steeering wheel and the rack in the same position. Theres also a CLOCK spring inside the steering column. If you rotate the wheel too far either way,,, more than when you turn the wheel LOCK TO LOCK,,,,it will break.BC
BC
Dave
Haven't tried it, but seems like a great way to accomplish this simple task.
When you put it back in, and reconnect the ends, push the wheels so they are straight again, and then reconnect the sterring shaft and assuming the steering wheel never got turned, all will be well.
If I were you, I'd pick up a service manual. This is probably the biggest PITA job on the car if you are using jackstands.
The job was done by a vendor up in your area of the woods.
It is imperative that u use this Bolt 1 time & Throw it away ,U may use the Old bolt to get the balancer back on & Rattled Up ,,Or see if u can Find Another Bolt Same Size But a inch or so Longer ,This will help u get the balancer all the way on the crank, Dont Forget Put the New Balancer Bolt in Before Tqing it down to 240
The bolt is a one-time-use fastener.
1) Rack doens't need to come all the way out. Just enough so you can get to the crank
2) May want to consider replacing your PS hoses, since you'll have both of them disconnected at the hard to get a end. Think about replacing both belts too, while everything is apart.
3) Unless the balancer is only a smidge off the crank, use a threaded rod to re-install the balancer. Reusing the old bolt to press the balancer on could result in damaged crank threads.
4) Crank threads are M16/2.0 pitch in case you need to buy the threaded rod. Same size tap is ~$15 from NAPA
5) Pin the crank while you have everything apart. Only takes 15 more minutes at this point.
6) Use a new bolt for re-install and be sure to follow GM's torque specs. The angle spec may be difficult to hit, a couple of degrees off shouldn't hurt.
Good luck!!
