C6 shifter install
Old Nov 9, 2007 | 11:10 PM
SoCal-Z06's Avatar
SoCal-Z06
5th Gear
Default C6 shifter install
Thanks Gene for the prompt service and Patches for the install notes. Now since I drive better than I wrench, I peeled of some greenbacks to have my local guy bust the nuts on the 2003 Z.
Nice position for me and a shorter throw.
Problem is the installed shifter has no "springed center" in the neutral gate. The shifter is just floating rather than having that center feel at the 3-4 gate while in neutral. And it's a little hard to get into 1st gear. Anyone care to weigh in on this and tell me if something got missed or is there an adjustment? Thanks in advance and it's great to have some plastic back under my a** after a 10 year hiatis!
Old Nov 10, 2007 | 03:59 AM
BlackZ06's Avatar
BlackZ06
What brand of shifter ??? Your title implies it is the C6 stock shifter ... is it the GM one ??
Old Nov 10, 2007 | 10:13 AM
SoCal-Z06's Avatar
SoCal-Z06
5th Gear
It is the GM C6 shifter.
Old Nov 10, 2007 | 10:43 AM
Oldvetter's Avatar
Oldvetter
This is a new one, I never heard this before. I think the spring centering is built into the transmission, hence people do the anti-venmon (sp?) mod. I hope your installer transfered the little plastic "button" from the bottom of the old shifter to the new one? Do you have the old shifter? Does it have the "button" on the bottom? I am assuming the new shifter comes without a "button", I am not sure, Gene would know.
Old Nov 10, 2007 | 11:02 AM
hotwheels57's Avatar
hotwheels57
The oem shifters are encased in a rubber "bearing" rather than a nylon 'bearing" at the pivot point which the after market shifters use. I do not believe there is any spring(s) inside the oem shifter. That could account for the vague "neutral gate". Look at your oem shifter and you'll see what I'm referring to. The lever self centers by virtue of the rubber encasing the lever.
The "local guy" who installed your new shifter may not have used the oem alignment pin to maintain perfect neutral alignment during the installation procedure. That could account for the difficulty getting into first gear.
If that's the case, the radio/console surround trim would have to be removed again, and the four 1/4-20 fasteners loosened to allow the shifter mechanism to be adjusted once the alignment pin is inserted. Then the fasteners re-torqued to 8-10# torque.
The plastic "button" on the bottom spherical ball is critical. It is not only a bearing, but it reduces vibrations/noise since there is otherwise metal to metal contact. Since the C6/Z06 shifter from GM/Gene comes complete with the "box", I would imagine it comes with the plastic bearing.
Old Nov 10, 2007 | 11:03 AM
SoCal-Z06's Avatar
SoCal-Z06
5th Gear
The old shifter is an assembly with a "plunger" comng out the back. Presumably to connect to the trans. There is no spring loading on the old shifter that is sitting on the bench. I don't see any button either. Would it have been on the plunger or is it internal to the assembly?
Old Nov 10, 2007 | 11:13 AM
hotwheels57
This is an image of an after market B&M "Sport" shifter. The plastic "button" or bearing snaps into place on the bottom spherical end that goes into the transmission.
As I said, I'd imagine that if you bought the entire assembly as shown in the first image, then the plastic "button" should already be snapped into place. The GM C6/Z06 shifter is a very complete assembly.
I have no idea why your "local guy" would remove the "button" from your oem shifter.
From the second image, you can also see that this particular after market shifter has sufficient space above the mounting plate to enclose not only the nylon "bearing", but some shifters also have springs to center the shifter (KIRBAN, HURST, CALLAWAY). I've had my B&M "Sport" shifter apart and it only has the nylon "bearing", no springs.
It sounds like your "local guy" removed the entire oem assembly from your car and installed the entire GM assembly you purchased. That's how most people install this shifter since it's already factory assembled. I think an adjustment and alignment with the neutral pin should cure your problem of getting into first.
Old Nov 10, 2007 | 11:21 AM
Last C5's Avatar
Last C5
Sounds like the neutral pin wasn't depressed during the installation.
Old Nov 10, 2007 | 12:15 PM
Oldvetter's Avatar
Oldvetter
That the installer may not have used the neutral alignment pin and that could account for it being difficult to get into first.
BUT, what about him losing the 3-4 spring centering ?
Old Nov 10, 2007 | 06:42 PM
Last C5's Avatar
Last C5
What position was the old unit in when it was pulled and what position was the new unit in when installed??? Without knowing if both neutral pins were depressed you don't know how the linkage shaft was lined up. Even when both pins were depressed, you have to be careful to install the new unit so that you're dead center on the linkage shaft's detent (place where the bolt goes through) or you experience the hard into first or whatever gear syndrom. A good double check is to note the marks on the elongated bolt holes of the old unit and start with the new one oriented the same.
Old Nov 10, 2007 | 07:11 PM
SoCal-Z06's Avatar
SoCal-Z06
5th Gear
Thanks guys. This is a big help. Pending anyone elses observatuons I'll get back in there with the neutral pin and allignment issue to address. Stay tuned next week and thanks again. This forum is awesome!
Old Nov 10, 2007 | 08:00 PM
blackconv's Avatar
blackconv
I know exactly what he is talking about. The shifter is the '08 Z06 shifter assembly, complete with **** and housing. It is very stiff out of the box, overly stiff to a fault, and will not return to neutral position by itself. It is solid mounted with no rubber bushings. I may go back to the C5 shifter myself unless this one loosens up a bit. Time will tell.
Old Nov 11, 2007 | 09:03 AM
blackconv's Avatar
blackconv
Default '08 Z06 shifter
SoCal-Z06,
Check your PM.
To C6 shifter install
